Question about Dishwashers
Why do I have a pudle of dirty water at the botom of my new dishwashers. series #500,700
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    clogged outlet, perhaps?
I recently bought a second hand kitchen dishwasher inc, never worked one before but i know were to put tablets dont know why theres a puddle of water on the bottom , if it is clogged how do i clean it out? and why is there another part on the bottom with salt wrote on it? please could you help me....
Posted on May 10, 2008
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Electrolux professional series not pumping water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
Frigidaire gallery prof series dishwasher- arms dont work
Call a certified repair company as it sounds like the sump is clogged for some reason.
Jan 29, 2010 | Dishwashers
Water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
Jan 26, 2010 | LG Dishwashers
Dishwasher drain pump flapper (inlet side)
My Quiet Series does the same thing and I wondered if the orange flapper has gone bad and lets the dirty water drain back from the hose sloping up to the garbage disposal. Did you get an answer to this question? The dishwasher seemed to work fine and then it suddenly started leaving food particles on the glasses.
Jan 15, 2010 | Dishwashers
Used the dishwasher last night and when I emptied it this morning, there was a pool of dirty water standing in the bottom
Your pump is clogged. You must disconnect the power and the drain hose and water feed pipe. Pull the dw out and lay it on its back to access the pump.
Jan 03, 2010 | Frigidaire Professional Series 24 in....
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
I get an pudle of antifreez in morning under car
Sounds like the water pump is going bad.
Mar 16, 2009 | 1998 Buick LeSabre
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
