Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I just bought new ink cartrides color and black, because i havent used the printer in a while and i recently got a laptop and i purchased the ink tonight and just inseerted it into the printer and now the pages are printing blank.
    Problem Solver:
  • 3 Answers
There must be a printer setup button. Browse thru and will find clean cartridge menu. run it few times might solve your problem. I have not seen the printer but some brother printers have this option i have used to solve similar kind of problems
Posted on Sep 02, 2010
Need to print using hp 6110 with only black ink cartridge
Try to reset color ink level ,see how in the following link
http://atta-metro.blogspot.com/2010/03/reset-ink-level-printer-hp.html
after you complete , reset make sure your file free form colors , other wise print will ask you for change color , hope this help you
Mohamed Hejazi
Afaqnama - Tripoli Libya
Ipg@hplibya.com
Mar 21, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Why it can't print?
It won't print if your ink cartridge is empty. Check the black and white and also the color cartrides by doing the following:
1. Slide your hand underneath the front cover and open up the case.
2. Find your ink cartrides usually located on the left on the inside of the casing.
3. Gently pull up (usually) on the cartridge and take it out and shake it. You will know if it is empty or full when you shake it. If the color is full but the black and white is out that is probably the problem. Many printers won't work if the black and white cartridge is empty because that's usually the primary color.
4. Go to Walgreen's or a similiar store and purchase a new cartridge and then just reverse the steps putting it back in. Make sure you take note where each cartride is located when taking them out and put them in their correct position when you put them back in.
This should solve your problem and you should be printing again in no time flat!
Dec 22, 2010 | Epson Stylus Photo R390 InkJet Printer
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have recently bought new ink for my brother mfc 255cw. While it was running low ink, it would print out copies colored purple. even though I have already purchased and replaced all the ink cartridges, it...
I would suspect your inkjets are blocked Black and blue =purple so the other colors are blocked up Use the nozzle cleaning function to try and remove the clog Run nozzle check after cleaning mode till all colors print correctly
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Office Equipment & Supplies
New color cartride not printing in color - printing in black and white
If you are not using factory new HP ink and cartridges then that is most probably your problems.
If you are using HP factory new cartridges, then contact HP technical support and inform them that you have a defective cartridge.
By the way, you did take the tape off of the nozzles and contacts, didn't you?
Don
Jun 19, 2009 | HP Deskjet 3845 InkJet Printer
Color ink cartridge
Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
Cartridge recommendations
You can purchase Canon cartridges directly from Canon here. The BC-10 is a cartridge that prints with black ink only. The BCI-10 is the replacement ink tank for this cartridge (a new cartridge comes complete with an ink tank). The BC-11e is a cartridge that prints both black and color, and has two ink tanks, the BCI-11 black and BCI-11 color. A new BC-11e cartridge comes complete with two new ink tanks.
Oct 03, 2008 | Canon BJC 80 InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
87 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
