Question about Pentax ME Super 35mm SLR Camera
Hello I just started using my camera again after 5 years. I put new batteries in it and turned it on but I can't see anything through the viewfinder. And yes the cap is off.
    Brigadier General:
  • 3,006 Answers
Unfortunately, your camera was either stored away after the battery failed, causing mirror lock-up, or during storage the camera shutter operated, there was a long exposure in the dark and the battery failed with the mirror still up.
Either way, you have a locked-up mirror. You've tried the usual cure, a new battery, but as your camera was sitting for so long there's likely been a bit of gumming up in the works. One or both of the following has likely happened:-
  1. The lubricant films inside the camera have dried out;
  2. The foam light seals and the foam mirror buffer have decomposed into a sticky, corrosive, black goo.
A professional CLA and foam seal replacement is the official fix (CLA=Clean, Lubricate, Adjust) but the ME Super is very labour-intensive to strip down and there's a high risk of breaking unobtainable parts during the job. The cost of the work far exceeds the camera's value as well. For both these reasons, very few professional repairers will even touch your model and if they do will make it clear that the work is at your own risk and must be paid up-front.
From this point on, you may have gathered that you officially have a write-off suitable for spares only, but don't despair as there are a few things you can try with the lens removed (a lens can also gum up and prevent the body from operating correctly).
First, double check that your batteries are good (new ones can be faulty) are correctly inserted, are clean (they should not be handled by greasy fingers) and that the terminals in the battery compartment are bright and clean
Next, check out the foam issue: there are almost no cameras left from when yours was manufactured with the original foam. It's either been replaced with modern improved material, turned to goo, or the foam crumbled away. In front of the lower edge of the viewfinder screen, there will be a foam mirror buffer which is there to make the camera quieter by deadening the slap of the mirror as it flips upwards. It's very common to find that it's turned to goo and has glued the mirror in the locked-up position. With the camera turned off, gently use your fingernail on the front edge of the mirror to try and prise the mirror down a little. If it doesn't budge, try slipping the tip of a blunt blade (such as a dinner/butter knife) between the mirror and the screen and working it side to side to break the adhesive bond. Be careful to only slip the tip of the blade inas you don't want to scratch the mirror/screen, and you certainly don't want to smear goo over the screen. Don't worry about damaging any remaining foam as it's going to have to be replaced anyway. If this works, you'll be able to pull the mirror down a little and it will spring back up. Now turn the camera on and the mirror should flip down.
If this doesn't work, then try leaving your camera in a dry and warm environment for 24 hours. This can soften any dried out lubricant films sufficiently to free them off. You may also need to slap the camera baseplate firmly down onto a flat surface to free things off and work as many of the manual controls as you can to try and redistribute the internal lubricants. Don't give up on this too soon as it's your last best hope short of stripping down the camera, so also be prepared to give the body some firm taps with something like a rubber mallet (or the heel of your shoe). Remember that you're on a hiding to nothing here as the camera is already a write-off. You may need to repeat this "heat and persuade" method a few times.
If all this has failed then you have two choices: sell the camera as "spares or repairs" for whatever you can get (not much) or obtain a service manual (such as this free one courtesy of robertstech website) and try to DIY, but be warned: there are a lot of soldered joints to be tackled.
If the repair has worked then pat yourself on the back and order yourself a foam seal and buffer kit from your preferred vendor on sites like eBay and Amazon.
If all has failed then at least you'll have gained valuable experience for your next camera repair attempt and can console yourself by getting another complete replacement SLR outfit for free via FreeCycle or Freegle. As 35mm gear is now largely worthless except for specialist collectable items, many folks prefer to pass the equipment on rather than have the hassle of selling them. I've acquired a wide range of makes and models for free in this way over the last few years and the trick is to keep a regular close eye on the offers and to respond quickly with a personalised and polite reply.
I wish you the best of luck with resolving your issue, please take a moment to rate my reply.
Posted on Sep 02, 2010
When I turn the camera on the lcd and viewfinder only display setting icons the rest is black. The lense does extend. Display and viewfinder work in view mode. Whats the problem? Is it worth repairing? Is...
Hi there, Here is something to try:
1. Set the camera toTV mode
2. Set the shutter to 15 sec
3. Click to take a photo/image/video like you normally do.
4. During the 15 seconds _a about hal way into it 7-8 seconds) open the battery door/cover
5. Insert the batteries again and close the camera battery door.
See if it works?
Hopefully it does. I hope this helps you out!
Feb 13, 2011 | Canon PowerShot S2 IS Digital Camera
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
Finepix S1000fd just suddenly quit working...
I'm not sure how old this is, but I had this identical problem on my Fujifilm Finepix S1500 and the solution was embarrasingly easy and it may be related to this same problem. If your camera has a viewfinder, see if there's an image there. If so, look to see if you have a EVF/LCD button or something similar on the back of the camera. If so, press it. What had happened with me is that my wife likes using the viewfinder for framing and she presses that button to turn off the rear LCD and on the viewfinder. Maybe the button got pressed accidentally. Press it again and it should switch back. Hopefully this is the solution.
May 26, 2009 | Fuji FinePix S1000FD Digital Camera
Power light comes on, goes off, comes on, goes off repeatedly
If it has been left unused for a year,the battery had probably died - it may attempt to charge, but won't hold a charge. Replace it.
Mar 26, 2017 | Canon XL1S PAL Mini DV Digital Camcorder
Camara can't be turned on normally
I have to take out batteries and put them back a few time to turn on my camara in display or viewfinder mode. At first i doubt my battery's problem and replaced with new batteries, it was the same
Jul 18, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Sony Camera DSC-W30
Shoot 10-15 times hard thats all..
Jun 08, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
LCD and viewfinder malfunction
There is a documented malfunction with this camera, and Nikon has issued a service advisory and form you can send in with the camera so they fix it. Click on the following link, send in the camera with the form, and Nikon should fix it for free (assuming the problem is the one documented by Nikon) . I had to do it about a year ago, and the same thing just happened with my brother's camera.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/cp_service_form.pdf
Mar 01, 2008 | Nikon Coolpix 5700 Digital Camera
Olympus C-3000 Zoom telescoping lens problem
The small gears that link the viewfinder and lens may be out of sync. If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR! Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way. Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
Mar 20, 2007 | Olympus C-3000 Zoom Digital Camera
Pentax ME Super 35mm SLR Camera Logo
195 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
