Question about GE 24 in. GLD5850LCS Stainless Steel Built-in Dishwasher
GE dishwasher is making a grinding sound
My GE dishwasher is making a grinding sound when it runs, everything is working properly, except for the grinding. I think it something stuck in the filter but i don't know how to get the filter off.
  • annabelle00 Jun 02, 2008
    I'm having the same grinding problem. Everything works, it just makes this bad grinding/rumbling sound intermittedly when running.
  • Anonymous Mar 21, 2009
    again working but sounds terrible
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
DISHWASHER PROBLEM
this looks like a physical damaged you should call your service centre to get it serviced.
Thanks
Iqbal
Apr 07, 2008 | GE Nautilus 24" Built-in Dishwasher
Grinding sound in FGHD2472PF frigidaire professional
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
Aug 14, 2014 | Frigidaire Professional Series 24 in....
Dishwasher will not drain I think it:s the pump
It will help if you provide the make and model of dishwasher. There can be several reasons for dishwasher not draining. The most common is blocked filters or drain hose. Also ensure the kitchen side of drain is clear. If pump is running but making grinding sounds then something is blocking the drain pump. If you do not hear pump running sound then the dishwasher may not even be getting to the drain cycle for other reasons.
Apr 19, 2013 | Dishwashers
Everything seems to work properly but the sound that it makes is irratating and did not make such noises when first purchased
Mine is also making an irritating grinding noise. There may be a solid object stuck in the chopper. I just don't know how to access the chopper.
Sep 05, 2011 | Frigidaire Professional Series 24 in....
GE disposall gfc 700 gets stuck
It sounds like the internal works are starting to corrode. You can remove the rubber shield and use a flashlight with the unit unplugged of coarse and look to see if something is caught under one of "teeth". If you don't see anything, then replace the unit.
Mar 21, 2009 | Little Giant SDS-10 Sewage Disposal System...
Grinding/Rubbing noise?
the unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain.
if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump.
its not hard to take apart and you will find whatever shouldnt be in there.
Dec 29, 2008 | Dishwashers
Power outtage blues
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
Dec 13, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 24 in. GLD5850LCS Stainless Steel Built-in Dishwasher Logo
1,253 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
