Question about GE GTS22KBP Top Freezer Refrigerator
I forgot my freezer open last night and when i woke up, there was a sound almost like the motor was trying to catch up. it's been 24 hours though and the sound is still there. what can i do?
    President:
  • 1,891 Answers
Ck the evap fan in the freezer / sounds like the fan blade has come loose from the shaft . you will have to nstall a new fan . mm if you find this to be the problem ..
Posted on Sep 02, 2010
Kenmore upright freezer
order a new seal at the link I provided or ebay or your choice
also check the lid or door adjustmens and obtain specific help instructions at the link I provided
Appliance Repair Help Troubleshooting and Appliance Parts
Apr 08, 2017 | Kenmore Freezers
DAEWOO FRSU20IAI FRIDGE FREEZER NOT FREEZING AT THE TOP BUT FREEZING AT THE BOTTOM AND FRIDGE IS NOT COOLING
I'V JUST HAD THE SAME PROBLEM AND IT WAS THE
EVAPORATOR FAN MOTOR . TOOK ME A WHILE TO FIND OUT BUT GOT IT SORTED . EASY FIX THOUGH .I FOUND OUT IF THE COMPRESSOR IS RUNNING THE EVAPORATOR FAN MOTOR SOULD BE RUNNING ALSO, OPEN THE FREEZER DOOR AND HOLD THE LIGHT SWITCH IN YOU SHOULD THEN SEE THE FAN SPIN . IF ITS NOT ITS BROKE. BEWEAR THOUGH AS MINE SPUN AFTER SWITCHING THE SUPPLY OFF FOR 24 HOURS BUT AS SOON AS THE FREEEZER WAS COLD IT STOPPED ALL TOGETHER AGAIN . MOTOR MUST OF BEEN BREAKING DOWN AT A CERTAIN TEMP!
Nov 03, 2011 | Daewoo Refrigerators
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Magic Chef compact fridge. There was a lot of ice build up in the freezer compartment. I attempted to defrost it last night, but I also tried to break away the ice before it was completely...
either the defrost heater element or defrost thermostat is open behind the rear wall where all the ice buildup was and is bad or the defrost timer in the front area isn't working to defrost the unit on a 12 hour schedule,you will need to test each component
Oct 14, 2010 | Refrigerators
Freezer door won't open
k i would take say somthing hot or warm that you can melt the ice with (hot water in a contaner) and drag it aacross the ice
Jun 07, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Water keeps running
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
Feb 16, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
Hello schlucks
welcome to fixya.
You said, Your AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
When the door to the freezer was left open all night,the moisture from outside caused the water line to the water dispenser to freeze!
What you need to do is to move all the articles from your freezer to a spare or second freezer
temporarily.
Then turn off the freezer compartment of the first unit where the water is not depensing .
you will need 12 to 24 hours untill the line defrosts.
If the dispenser works sooner then don't wait any longer to restart the freezer.
In some models, the fact that the freezer is turned off may affect the power in the dispenser untill the freezer is turned back on.
After you finish defrosting and turn the freezer back on. give it 24 hours to get back to running temperture.
Then reload the articles agin.
BUT DO NOT TAKE 20 TRIPS TO BRING THE PACK AGES AND LOAD IT, LEAVING THE DOOR OPEN AGAIN!
Bring the articles to the freezer and load it straight awy quickly and close the door.
This will solve your problembarring any damage to the dispenser!t
Thank You for having me advice you.
Huuum
Please remember to leave a rating!
I'm sure you are solved!
Some info!!!!!!!!!!
cold air to the bin and make it colder.
Water and Ice Dispensers
(on some models)
Depending on your model, you may have one or more of the
following options: the ability to select either crushed or cubed
ice, a special light that turns on when you use the dispenser, or a
lock option to avoid unintentional dispensing.
NOTES:
■ The dispensing system will not operate when the freezer door
is open.
■ After connecting the refrigerator to a water source, flush the
water system. Use a sturdy container to depress and hold the
water dispenser lever for 5 seconds, then release it for
5 seconds. Repeat until water begins to flow. Once water
begins to flow, continue depressing and releasing the
dispenser lever (5 seconds on, 5 seconds off) for an
additional 2 minutes. This will flush air from the filter and
water dispensing system. Additional flushing may be required
in some households. As air is cleared from the system, water
may spurt out of the dispenser.
■ Allow 24 hours for the refrigerator to cool down and chill
water.
■ Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
Oct 03, 2008 | Amana Refrigerators
Roper Refrigerator, top freezer leaking water into refrigerator
Hi I reckon you gave either an ice block in the defrost drain system or a blockage caused by loose food bits. You can clear the ice block if you keep the fridge off for 24 hours leaving both doors open. If you have a small table fan to circulate warm room air you could speed up the process.
The second type of block with food bits may need you to open the internal rear panel of the fridge and push through a stiff wire to clear the blockage.
Jul 15, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
GE GTS22KBP Top Freezer Refrigerator Logo
54 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
