When i power copier on i get this error message"malfunction detected call representative c-0048" i broke bottom drawer switch that bopens bottom compartmeen and i cannot get it open i dont think this has anything to do w/ error message as i was advised that c-0048 erroer message has something to do with a fan needing cleaning and found this site while looking for dealer/svc ctr nearby and would appreciate any help or advice you can provide serial# is 6113598 and id is A 0987
Problem code c1039 for d-i 620
Try opening the front door with the copier on, remove the small cover on the right hand side (held on with 1 screw) press the reset button then close the door. This will reset the error, unfortunately if the copier still see a fault the error will return and a service call will be required.
