Question about Cell Phones
NO TIMBRAN LAS EXTENSIONES UNILINEAS EN CONMUTADOR PANASONIC KX-TA
SOURCE: LAS LUCES EXTERIORES NO ENCIENDEN
i am getting the problem in graphic card . dispaly cannot change ,and cannot change setting in display , plse give solution or solve this problem.
Posted on Feb 05, 2009
  • 4 Answers
SOURCE: kx-ta 616
try 600
Posted on Feb 26, 2009
  • 82 Answers
SOURCE: Como ver las extensiones de los archivos???
sorry my spanich is bad.
Posted on Aug 02, 2010
bbl242003
  • 1637 Answers
SOURCE: manual telefono panasonic kx-tg2258 en
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 18, 2011
  • 4961 Answers
SOURCE: puntos empire
correo no deseado
Posted on Aug 23, 2012
Hello there. Please tell me, does the Panasonic KX-T77330 have an inbuilt voicemail system?
A 7730 is a Panasonic phone that can connect to one of 18 or so different systems. Voice mail can be in the system or external to the system. The phone doesn't have VM on it. External VM has model numbers like TVA/TVS and connect to TA/TD/TDA/TAW and 123211 models. Internal models have names like SM or ESM and install in TA/TDA/TAW systems. No voice mail fit in the old KXT-308/616 systems as there's no integration.
Carl
Aug 04, 2011 | Panasonic KX-T7730 Corded Phone
I need in-home repair on a panasonic kx-t40810 bus/home phone system using kd-t7030 and kx-t7050 sets. Is there a company in houston, texas who can do this work?
A 30810 KSU has a value of about $100. The street price of the TA-824, carded 3x8 is about $250.
A service call for your in-home repair probably starts at $100. Do you get the hint?
In between, I have a TA-624 that I'd let go for $150.
Carl
Feb 03, 2011 | Panasonic Lands Phones
Panasonic kx-t7030 corded phone has lost its fwd/dnd abilities how do I get the light to come back on?
Somewhere in your user's manual you will have code instructiohns for CALL FORWARD. It starts with 71. In a TA series it's 711+ext+#. In a TD 710x+ext+#. The conditions vary, and the TA has very limited forwarding codes 1/2/3
In a TA you can also press the FWD button and dial 1+ext+#.Your other choice is 2.
Both of those are done while listening to intercom dial tone.
Carl
Nov 17, 2010 | Panasonic KX-T7730 Corded Phone
Do not know how to set the "ring over busy" feature on the panasonic KX-T7731
Panasonic calls that "call waiting". As answered previously, dial 7311# and 7321# on the intercom for a TA series system.
Carl
Aug 20, 2010 | Panasonic KX-T7731 Corded Phone
Does the panasonic kx-t7330 telephone system have a messaging serivice?
It all depends on what you mean by "messaging service." A 7330 instrument is just a phone that is forward and backward compatible with about 18 different Panasonic phone systems.
Each phone has the ability to light a MESSAGE button and give limited visual information to an inside caller, but it requires additional hardware to have a VOICE MAIL system. In the TA-624 which was the common system available when the 7330's were introduced, the only "system" voice mail was the TVS (in the U.S.) external voice mail box.
I hope this answers your question. You can view the features of the TA-624 here. http://www.public.carl.airpost.net/Pana/TA-624/624user.pdf
Carl
Aug 15, 2010 | Panasonic KX-T7730 Corded Phone
I want to call other extensions using our KX-TA30850 phones. Can you help?
If it's really a TA-308 cabinet, then the dialing plan is the same as a TA-624 or 824. The extensions are numbered 101-108.
Carl
Aug 12, 2009 | Panasonic KX-TA308 Phone
Manual
Not exactly. The 7735 is just an instrument. It is forward and backward compatible with about 18 Panasonic systems. If the system is fairly new, it will be a TA-624 or TA-824.
Try looking for the system cabinet and then go here http://public.carl.airpost.net/ for the proper OM or User's Manual.
Carl
Feb 23, 2009 | Panasonic KX-T7735 Corded Phone
Change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
Aug 25, 2008 | Panasonic KX-T7730 Corded Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
