Question about Garden
Fuel oil mix for a Poulan 14" saw ? - Garden
    President:
  • 2,220 Answers
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Posted on Sep 10, 2010
  • dontbother10
    dontbother10 Sep 10, 2010
    McCulloch, Poulan & Wen; recommend 40:1.
    1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
    4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Poulan 14" what
The fuel ratio is 40:1, that comes out to 3.2 ounces of 2 stroke oil for every one gallon of gas. If you have the model number you can retrieve a manual from www.poulan.com
Sep 05, 2011 | Poulan 14" Chainsaw
New 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the oil to gas mixing ratio for a poulan SM 4018 Pro chain saw?
The ratio is 50:1 fuel to oil using fresh fuel and a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Be sure to mix in it's own container, and shake thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 10, 2010 | Poulan Garden
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Fuel mixture for Poulan 245 and 306 chain saw's
245 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/30945e6822106f5388256b3500246efa?OpenDocument
306 here
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9a98d7ae6c77deaf88256b350024ae42?OpenDocument
I use 50:1 in everything.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Jan 26, 2010 | Poulan Garden
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I would like the fuel mixture for my poulan chain saw. %oil,%fuel
If you don't know the model, then go with a 35:1 or 40:1 ratio. 40:1 seems common on most smaller saws from Ryobi and Poulan is a relation to those. The 35:1 suggestion is just for a little buffer in case. Generally it is ok to run a richer oil mix. It just means you may have to change spark plugs more often, however, your combustion chambers will be better lubricated and probably last longer!
Sometimes there is a little sticker or marking on the fuel tank cap or somewhere near it that indicates advisable oil:fuel ratio... Have a close look, it may be indicated somewhere on the saw itself.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
341 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
