Question about Sharp (AN-XR10LP) Projector Lamp for XR10X
Would like to purchase a xr10x sharp projector to watch EURO 2008
Should i buy this projector for this purpose, how much are replacement lamps?
Dont pay for simple advice, is my best advice
Posted on May 12, 2008
I have a sharp notevision DLP xr10x projector. Two red lights, one is the lamp, the other standby/power. I changed the lamp but nothing changed. I can't even turn the thing on. Any ideas?
Hi Stephen,
Do you hear any fans starting when you turn on the projector? Try unplugging and then plugging in the projector. Make sure that the lamp door is secured as the projector will not start if it is loose. You should also reset the timer for your projector. The manual can be found on the site of www.allprojectorlamps.com.
Nov 04, 2013 | Sharp Notevision PG-C45X Multimedia...
My Sharp Projector xr10x will not come on, two LED solid red lights are displaying, bulb was recently replaced, was working fiine until we turned it off and turned it back on Please help!
The fault seems related to the lamp but it will be good to revisit the replacement of the lamp, check the lens cover section , the lamp cover as there are safety micro switches that need to be active to start the lamp. Also the filter must be cleaned. Check the power supply , check the connectors and fuse. If none of these rectify then the fault can be within the power supply or processor board.
Oct 30, 2011 | Sharp XR10XL DLP Projector
Is the an- xr20lp and an-xr10lp the same lamp or does one have more hours than the other, what is the difference?
the xr20lp is 275W, 2300 lumens
the xr10lp is 220W, 2000 lumens
see spec at
http://www.sharp-world.com/products/data_projector/xr20xs/spec.html
They seem to be compatible as some sellers are selling the 275W version for the XR10X.
Jan 26, 2011 | Sharp AN-XR10LP Projector Lamp for XR-10X,...
After replacing bulb, when the projector was turned on again, dark cloud area in bottom area of screen?
Please check the light tunnel and the reflector glass in the projector ,
it seems that the light tunnel or the reflector glass is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 16, 2011 | Sharp (AN-XR10LP) Projector Lamp for XR10X
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
Jerry
Lampdeng Limited
Dec 13, 2010 | Sharp (AN-XR10LP) Projector Lamp for XR10X
I have a Sharp xr10x, I had one before, on the older one the color wheel went out and the repair shop said it would cost $700 to repair it so I bought the current one on e-bay for about $200.00 since it...
whatever service shop told you $700 was out to hose you. there's no way with parts and labor it should be over $300. so to answer your questions: yes, sharp calls it a filter, but only on some models. on the xr-10x, it's a c/w assy (PFiLWA087WJZZ). to extend the life of a colorwheel, and any other part of a projector, keep it cool, clean, and free of dust. dust holds in the heat that the projector is trying to expel. blow out dust with canned air. and you are going to need a colorwheel. you can have them replaced for $300 each, or buy the colorwheels and replace them yourselves. either way, you're going to want an authorized sharp service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 21, 2009 | Sharp XR11XC-R Multimedia Projector
Sharp xr10x whining noise affects color sometimes not fan.
gas+heat=boom. learned that lesson myself.
sharp part # PFiLWA087WJZZ (c/w assy.)
remove the top (6 bottom screws, 4 back screws (not the one near the plug)). facing the front of the projector, the colorwheel is behind the front leveler foot and attached to the orange ribbon cable. you need to remove the lamp housing, the main board, the fan assembly between the lens and the power supply, and the lens assembly (optical engine). now remove the 2 silver screws holding the colorwheel assembly to the optical engine. that part number is for the wheel itself, so remove the 3 small screws to get it off. to install, repeat procedure. keep in mind which screws and which cables go where.
Apr 06, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Lamp won't turn on.
I have a sharp xr10x ..........the problem lies in the bulb it needs a warmer temprature for the gas to expand in the bulb to fire and light up... hold a hair dryer up to the side of it fo a while and then fire it up still holding the haidryer up to it till it starts it may take a couple tries... ( this is a fix if your having a no buld startup problem and you know your bulb is still good) THIS IS THE FIX IF**** the lights will blink green for a while then one red and one green then will (shut off at both red) and not restart***
i had the same problem and thought id have to get a new bulb but this is the fix....
Nov 23, 2008 | Sharp (AN-XR10LP) Projector Lamp for XR10X
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
