Question about GE Superadio III AM/FM
The mode selector switch on my GE Monitor 10 Model 7 2971A radio needs to be replaced. Can you recommend a source for this part? Do you have it available?
3 Suggested Answers
breddi2
  • 126 Answers
SOURCE: Old GE stove
Try company called Sundberg, they are online and generaly have what you need.
Posted on Apr 26, 2009
SOURCE: Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Posted on Nov 18, 2009
My 1999 ford explorer radio keeps switching to cd mode back to radio
Problem is with the source selector if the cd inside is scrachy or is not running propey due to any reason system is programed to switch to next source try to clean the inside of the system through air pressure from some external source
Aug 14, 2012 | Kenwood KDC-MP235 CD Player
BUZZES
This sounds like the temperature monitor is alarming because the temperature has not cooled down enough yet in your freezer. turn the monitor off until the freezer reaches proper temperature then you can turn it back on.
Jul 20, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
RCA rs2600 every thing works but the radio.When the source is switched to AM or FM no sound comes from the speakers.The sound works fine with the CD or tape.
Try to clean the selector mode switch with a contact cleaner like "electra"that safe to all surface plastic or metal.If still the AM and FM not working.You better replace the selector with identical rating parts.
Hope it may helps;
DON'T FORGET TO RATE:
RegardsVOTIT
Jun 12, 2009 | RCA RS2600 CD Shelf System
Vent selector inop
U have either lost the vacuum to the mode selector switch (in the dash control) or the vacuum mode selector switch is leaking in the ac/heater control in the dash, u can usually hear a hiss if it is leaking. the vacuum source is the engine, a small hose runs through the firewall on the passenger side to the switch from the eng vacuum source.
May 19, 2009 | 1994 Chevrolet S-10
How to set alarm and how to turn it off so that it is not used.
To turn on alarm, switch the selector lever to "Wake" and adjust the time shown. Then, switch the lever back to "Lock" and push the "Wake Mode" button until you see the selector dot (located on the bottom right of the time display) change to either the music or bell symbol; depending on how you'd like to be awaken.
To cancel the alarm, simply hit the "Cancel" button once, then press the "Wake Mode" button until the selector dot disappears.
Mar 10, 2009 | GE 7-4837 Clock Radio
Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
Mar 07, 2009 | GE 7-4837 Clock Radio
Not sure how to connect other devices
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Feb 25, 2009 | Philips HTS-6500/37 System
Switching Input on GE Stereo Monitor
I tried for a while to get my dvd to work. I went to the menu, from my universal remote that totally works. Went to the menu, then channel set up, and switched the VCR1 channel to 00Enabled. When I want to watch a dvd I press 00 for my chanel and it works. I hope this helps all of you.
Dec 13, 2008 | Televison & Video
Konica minolta dimage z6 problem
Sony handle repairs to Konica Minolta gear (I think) good luck.
Feb 10, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Green color dot appears when moniotor switched off
I would first verify your system power settings (in Windows XP go to control panel, power options, then verify that nothing is set that could activate your monitor to a standby mode) - other versions of windows have something very similar. If all of these settings are correct, then unless the monitor is not working as required when switched on, i would recommend just leaving it be, possibly just take the time to unplug the monitor power lead instead of just switching it off. If however you feel you must fix this problem, try: http://www.lenovo.com/planetwide/select/selector.html for this model of monitor you will need the serial or FRU number in order to define the exact model.
Feb 23, 2007 | IBM E74 17" CRT Monitor
GE Superadio III AM/FM Logo
254 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
