I have a Freidrich zq10a10 installed thru the wall. They no longer make a model that fits this case. Any ideas for a replacement that doesn't involve tearing down the wall? The only unit I found that fits is discontinued Goldstar Dimensions: Sleeve Type: Q2 Height: 13 7/8" Width: 18 1/2" Depth W/Front: 20 11/16" Thanks
SOURCE: Is this the right unit? Can it be used with a sleeve?
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Posted on Jun 12, 2008
Coldcut
  • 1554 Answers
SOURCE: Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Posted on Jun 13, 2008
koolbreezes
  • 540 Answers
SOURCE: I need to replace a
As long as it fit inside the wall , go smaller and close the hole, or slide the new unit in the old case. & sealthe loose ends . or keep callng around..
Posted on Sep 08, 2008
relaga58
  • 158 Answers
SOURCE: my office room model dimensions are
u need 1 hp unit
Posted on Nov 25, 2009
koolbreezes
  • 540 Answers
SOURCE: I need a replacement front panel for an Emerson
Type in the brand name, go to the website, and type in all the model#,s and surf..
Posted on Dec 08, 2009
Error 59.51 on hp laserjet 4700
A 59.51 error would normally indicate a problem with the cyan drum drive motor DC controller. First of all I would recommend resetting the printer and unplugging it from the wall for a minute or so while it is off. Sadly if this doesn't clear the error any further fixes would involve cold resets, disconnecting and replacing components.
In which case it would probably be best to call an engineer unless your feeling particularly brave.
Sep 06, 2012 | HP LaserJet 4730 MFP Printer
I have Freidrich model #SC06H10D through the wall unit. I need new unit, but it has to be same dimensions as this one which is about 14 3/4" wide. Do you make one to replace this??
The FixYa website does not make or sell appliances or repair parts. What we provide is information on how to troubleshoot and repair all types of things. And sometimes, find things. With that said, here is a link to an identical (Model # ) to the one you want to replace. http://www.ajmadison.com/cgi-bin/ajmadison/SC06H10D.html
Good luck, I hope this helped you find what you're looking for.
Apr 14, 2011 | Friedrich Heating & Cooling
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Need replacement cover or grille for model # KM18J30
Johnson supply out of Texas has an account with Freidrich. They are an A/C supply house. I believe they are based out of Houston. I would give them a call and see if you can get one through them.
Mar 19, 2009 | Friedrich QuietMaster KM18L30 Wall/Window...
What do you need to do to put a woopellet stove pipe thru wall
I'm confused by your question. If you are asking what is involved in installing a pellet stove well it varies greatly from model to model. Generally speaking, most pellet stoves will horizontally terminate behind the stove itself as opposed to running thru the roof like a woodstove does. Pellet stoves require the use of electricity for numerous functions, one of which is power venting thru this rear terminated pipe. As far as clearances to combustables, you will find that pellet stoves are very forgiving in that department, with minimal clearances required. Once again all stoves are different and they all are rated indepentently so my best advice to you is find a quality pellet stove dealer and go in and see them. They will be more than happy to answer your questions. Avoid the big box stores as they have pellet stoves at a good price but offer NO service or installation and believe me, I am in the business, you will need professional service at some point during the life of your stove so don't save a couple bucks by going cheap. You will be happier for it down the road. Good luck.
Mar 12, 2009 | Napoleon Auburn Pellet Stove Heater
Sounds easy...but
Installing one of these between two cabinets and supported by the one above it is a pain ..but even worse if you don't have the installation directions. If you are relatively handy and have some carpenntry experience, I'll walk you thru the way I install them. First off, I assume you are installing this above a stove and betwwen two wall cabinets.. You need to do a little preparation work first. locate the wall mount bracket and you should have a packet of hardware ( primarily two long screws that will be used to support the front of the micro from the cabinet above) If you have all this.. you'll need to determine if you are going to vent the micro back into the room or plan to vent it outside. The simplest is to vent it back into the rook thru a charcoal filter but if you are going tovent it outside, you have two choices.. one is to vent it up thru the cabinet and outside via ductwork that you buy..if the microwave oven is being attached to an outside wall then it is easiest to vent it straight out the back ( i say this because you have to orient the blower in teh configuration that you are planning to use) Let's assume you will be venting this back into the room ( that's the easiest ) and move on.. The wall mount bracket supports the back bottom of the microwave oven when you secure it and the two long screws will be used to bring the front of the micro up against the bottom of the cabinet above it... I normally locate the wall studs and then buy and fit a 1/2 inch piece of plywood onto the wall where the micro will be mounted. The microwave will project out 1/2 inch further as a result of this plywood panel but.. you can use lots of drwall screws to the secure the plywood to the wall studs and then you can mount the wall bracket onto this plywood without having to worry about where the studs are and if it will support the microwaves weight. Mount the bracket onto this plywood piece. I will use drwall screws and add flat washers to them to provide additional support. Once that bracket is installed, you will need to figure out how you are going to provide power to the microwave. If you are replacing an existing oven then you will probably have a power fees inside the cabinet =situated above the microwave oven. If not, then you will need to provide a power feed for this. In the old days, most of these appliances were hard wired into junction boxes but nowadays, most appliances are treated as removable and all you will need is an outlet box in the cabinet above. I suggest you bore a hole large enough for the power cord plug to fit thru the bottom of the cabinet so that you can plug it in. The next part is the hardest to accomplish.. If you look at the top of the microwave oven, you should see two holes near thhe front and on top. Those two holes have floating captive nuts inside them that the long screws ( included in your hardware kit) will be used to snug the front of the micro up against the bottom of the cabinet above it.. The trick is to measure from the back wall out to where these holes need to be drilled in the cabinet above so that they line up. You can drill bigger holes than you need and use oversize washers if necessary. If this sounds complicated ..it IS.. i have put many of these in and unless you are actually doing one, youhave no idea how involved this can be.. even worse with ducting to the outside.... I hope this gives you some tricks on how to install.. And um.. if you do get this all together, you will need some help actually putting it in place.. You'll need to catch the back of the microwave onto the tabs of the wall bracket and then feed the wire thru the cabinet while you lift the entire thing up to start the screws from the cabinet down onto the top of the microwave. I'm a big guy and have done these myself but it is not easy.. Hope this helps you.. Lastly, here is a link to the GE website where you can download the user manual and search their FAQ for install details ( in retrospect, I just should have given you that info).. http://www.geappliances.com/service_and_support/literature/
Hope this helps you...
Sep 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
