Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The dishwasher beeps and shows a little wrench and F2, it will not cycle
  • Fisher and P... Master
  • 3,247 Answers
Looks like you do not have the user manual for this dishwasher.
Refer this site.
on page 24. F2 means the motor is having some problems.
You can easily take the motor rotor out for checking it. I am assuming the dishwasher was making some grinding noises before the fault appeared. It could be just a simple thing as a hard food waste item sitting in the cavity. (a bone piece or seed). Go to page 21 of manual and remove the filter plate. The rotor is attached to the impeller. Get it out and inspect. Also check the channel between the drain sump and rotor cavity. Use a thin rigid wire to clean it.
A replacement rotor can be got from this place if you are in US.
Please rate the solution if you found it useful
Posted on Sep 03, 2010
When i start to move my chair starts to beep shows little wrench and then stops dead....what can this be?
it is telling you that there is a problem of some sort. The number of beeps and the wrench can help you to troubleshoot the problem.
Jan 29, 2017 | Health & Beauty
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My 603 integrated keeps stopping mid cycle and beeps (3 x 2 short beeps). this can happen 2-3 times in the same cycle
I had the same problem; it turns out that there is a little plastic clip that holds the main circuit board in place and aligns the sensor on the circuit board with a little hole on the unit. This clip was broken and hence the circuit board was moving around, causing misalignment of the sensor and hence the unit would turn on and off during cycles. This may be your problem.
Dec 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dd603 stops while in cycle and beeps but no error codes show
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Nov 29, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishlex 302 SJ dishwasher on quick cycle beeps and shows 20 ...?
THATS GOOD NEWS AND YES IT IS THE TIME LEFT IN YOUR CYCLE HAVE A GOOD TRIP
Apr 11, 2009 | Dishwashers
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Oct 28, 2007 | Asko 24 in. D3350 Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
49 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
