Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My husband and I are separated. How can I reprogram my car's remote button (not an actual Sear's control)...so he can no longer use it, that is programed in his car as well. We have a three car garage, all equipted with Sear's garage door openers.
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and hold this for 6 seconds. This will erase all programming from memory and you will now need to program your remotes and keypad if you have one. Do this for each opener.
To program your remotes hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
To program your keypad, press and immediately release the smart/learn button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Sep 02, 2010
Testimonial: "Thank you so very much! I need to have safety assurance that this would work, to erase him car's built-in remote as well. Whew!"
How do I replace the IR sensor?
If you took the batteries out of your remotes to change them, they possibly lost their programming and need to be reprogrammed. I drop my controller often and have to reprogram it. All of the lights light up but the TV appears dead. Either find your control programming guide or look it up on the internet how to reprogram your remote.
Jan 06, 2015 | LG 42LG30 42 in. LCD HDTV
Fireplace remote control no longer works correctly
To re-sync your Honeywell 8220 transmitter to the valve: Turn the Local/Remote switch on your valve to Local. Then switch it back to Remote. Within 10 seconds of switching it to Remote, you need to press the Flame button on your transmitter. This will re-sync your transmitter to the receiver in the valve. Replacement transmitters and valves are no longer available for this system, they were discontinued by Honeywell and they are completely out of stock. Monessen Hearth Systems (now owns Majestic, Vermont, etc) has a retrofit kit with a new valve, pilot assy, and remote for these old RF units. (expensive, but cheaper than a new fireplace). FYI, aftermarket remotes are NOT compatible with this Honeywell system.
Nov 24, 2012 | Televison & Video
We have a Bose home theater system that just isn't producing sound. The red light on the little receiver indicates it's on and connected, but I don't know which button on the remote actually controls the...
if the light is red that means that is off, so try to turn it on, that will help and if it doe not work just unplug everything and run the setup again, sometimes the system lose the configuration
Dec 11, 2010 | Bose Cinemate Digital Home Theater System...
Remote doesn't switch to game mode
It won't let you switch to video/game mode?
If it's a universal remote, it may just be that the button is actually called TV/VCR instead of AV or input.
If it's the actual remote for the TV, then perhaps the button itself is no longer working (usually from repeated pressing or excessive pressure/twisting). Either that, or the digital circuit that controls the switch between inputs is no longer working.
Try accessing your TV's menu with the controls along the front or on the remote. Most TVs will let you switch through those menus.
Jun 03, 2010 | Symphonic ST419E TV
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not reprogram its remotes
Did you actually go to the power head and push the program button, then the remote button?
Is there a small wire hanging down from the power head? It's the antenna wire.
Jan 28, 2009 | Chamberlain 950CB Remote Control
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Remote Worked Until my husband played a video cassette
Change The Batteries and then try reprogramming the remote..
Dec 02, 2007 | Philips PM435S Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
153 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
