Question about Dell E173FP 17" LCD Flat Panel Monitor
No power circuit board shows no voltage - Dell E173FP 17" LCD Flat Panel Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 02, 2010
Vizio main board # 3655-0122-0150 7C
Board # 3655-0122-0150 is the main board not the PS board as mentioned in the previous message it can be purchased from shopjimmy but its not a cheap board...below is the URL for the board..How does the set behave? sound no picture, picture no sound, dead, has standby light, poor picture...ect
http://www.shopjimmy.com/vizio-3655-0122-0150-main-board-for-xvt553sv.htm
Nov 10, 2017 | Vizio Televison & Video
Vizio e390vl standby and on status good no picture.
The power supply must provide 12V as well as 5V. Your power supply module may be damaged. did you measure the voltages in circuit or after disconnecting the circuits. When no load is present, the power supply outputs must show 12.5 V and 5.3V. You will need to replace the power supply module if these voltages are not present. The main board may not have been the problem in the first place.
Aug 05, 2016 | Vizio 39" E390VL 1080p LCD HDTV
How much damage did I inflict when I plugged this 110v unit into 220v?
check electrolytic capacitors in power board printed circuit board see if voltage was over their voltage rating. Damage hard to say did the same thing to a printer got white smoke from capacitors . check if unit has a orderable 220v power board circuit board you could order. May you have blown up power circuit board hopefully and nothing else.
Sep 04, 2015 | Yamaha RX-V677 home theater receiver
Wiring
Not sure about the actual voltage, but the primary power board shows 94 V @ 2A. As this appears to be a variable speed drive, the voltage amplitude should vary depending on the speed potentiometer setting. The most likely culprit is the speed potentiometer. Poor design causes vibrations on the printed circuit board. This induces metal fatigue in the potentiometer terminations at the board. Eventually one or more terminals snap off. You could try removing the pot and connecting the wiper termination connection directly to the relative end for full speed? This is assuming you want it to run at full speed? Failing that you could try variable resistance settings and then replace the pot with a fixed resistance for the required final speed?
Sep 14, 2012 | Dremel Multi Max Kit
Menu bar shows code H 97 on model number NN-CD989S. started to cook microwave meal, the oven madepoping sounds and showed the H 97 then won't turn back on. there is a small sokey area below the...
This oven is programmed with a self diagnostic failure code system which help for troubleshooting -H97 and as described above "mica piece and burnt smell" sound like Inverter Power Supply. DO NOT try to repair or re-adjust preset volume on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very high current Operating a misaligned inverter circuit is dangerous due to the Very HIGH voltage and current that is produced by this board.
Defective board must be replaced with new one -INVERTER POWER SUPPLY.
Aug 23, 2011 | Panasonic Microwave Ovens
When I power up the unit it only shows Welcome and stuck there, after reset or unplug power it also shows Welcome. It is totally frozen at Welcome.
Hello
Its power board had got damaged. It ony supplies 5VDC to the board, which in turn energises the system control and display. There is 4 more voltages out from it is missing. You have to findi out it, and reason for its failure. Actually the swithcing process in the power supply board is OK. But without the above said missed voltages, there will be no motor voltages and mainboard chroma and decoder voltages. The system is very complicated in circuit nature, so without any previous expeience, never attmpt to reapir it. If you are well aware in digital electronics, you can do this. A high quality digital multimeter and a concept of soldering are also needed. I've given you the fault advice according to your post. Determine what should do. OK.
Mar 23, 2011 | Sony RDR-GX300 DVD Recorder
Microwave shows H98 problem. How can we solve it.
H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
Jan 01, 2011 | Panasonic NN-S541 Microwave Oven
Power button blinks 8 times and no picture. Sony KP-57WS510 projection TV
8 time blinks shows problem of High Voltage error in D board.
Please replace D Board of TV, let me know if you can replace the circuit board in TV to provide you D Board part number info.
Nov 17, 2009 | Sony Televison & Video
No power to hitachi projection tv in a coin operated game
the tube need high voltage to light up.but when used in a arcade game its pretty much just a monitor and need to make sure video is getting to the video circuits ,tvs have a OSD on screen display that offers information about the menu like brightness etc
Does the OSD show?
Can you hear high voltage?
Odds are if no picture then no high voltage if thats the case you need to troubleshoot the circuits and need a schematic and a voltmeter.Good Luck!
Oct 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Dell E173FP 17" LCD Flat Panel Monitor Logo
23 people viewed this question
Alun Cox
