Question about Dell Inspiron 1525 Notebook
Hi I have a dell inspiron 1525 and it always worked fine but now when I go to turn it on the start up repair comes up and runs. Then a window comes up that says "startup repair cannot repair this computer automatically". I click the send info botton every time and it restarts and brings up the same page. Someone please tell me how to troubleshoot this problem!!!
  • 70 Answers
It sounds like you "might" have a corrupted operating system. To see if your operating system is corrupt, restart your pc, press F8, select safe mode, do a system restore to at least 2 weeks prior to your problem. Restart, and it should work. If you are unable to boot into safe mode, then you have a corrupt operating system and you will need to reinstall windows. Just buy a cheap copy of windows xp online or if you have one laying around pop it in and follow the directions.
Posted on Sep 02, 2010
Testimonial: "Thank you So MUCH!!"
    Scholar:
  • 64 Answers
The first step would be to: When the black screen with white text comes up with two options: star-up repair and start windows normally, press the down arrow followed by enter to attempt to start windows.
if this works then you are done. If not, press F8 repeatedly as soon as you power on the computer (before the black and white screen comes up). This will give a much larger range of options than the normal two. Select the top-most option, "Repair your computer". This will be a different repair than the norm. It should bring up a window which list many options one of which is system restore. Click this option and follow the prompts attempting to restore the computer to an earlier date. It is likely that this will undo any erroneous changes causing issues. The computer should automatically restart and boot to windows.
//halfs
Hi I have a dell inspiron 1525 and it always worked fine but now when I go to turn it on the start up repair comes up and runs. Then a window comes up that says "startup repair cannot repair this computer...
hi zachgibbons,
Try this, restart your pc then press f8 continuously, this will take you to safe mode. then after that go to start>run> type in msconfig (windows xp) , and start>search> type in msconfig (windows 7)
this will open up the system configuration under the general tab
select the diagnostic start up then apply>ok>restart
Hope this helps,
thx
banaple
Sep 02, 2010 | Dell Inspiron 1525 Notebook
DELL INSPIRON 1525 NOTEBOOK : HELP !! my dell inspiron 1525 notebook will not start windows. the battery is fully charged and when i press the power button a black screen comes up and it says : "windows...
This sounds like the dreaded Windows Vista Black Screen of Death (KSOD). you might have a bad hard drive, but even more likely some software or a driver is causing a problem and caused Vista to get stuck. The repair will not work. You might be able to run a complete repair from the Windows Vista CD, if you have one. If you are not too experienced, take it to a reputable computer service center. If you are at all technical and have time, google your problem and you will see thousands of similar users with same problems.
This is one reason Microsoft released Windows 7 so soon.
Feb 16, 2010 | Dell Inspiron 1525 Notebook
My dell 1525 series will not go to my password screen or desk top.....when i turn it on it says windows error recovery...when i start windows normally....the microsoft corporation comes on then a blank...
try running diagnostics, when you turn it on when you see the DELL screen tap F12 until you see options look for diagnostics the run it. it will prompt if you have errors.
Feb 08, 2010 | Dell Inspiron 1525 Notebook
My laptops backlight turns off when i plug it in.it works fine when running off batt power
Maybe you select the save-power mode when using your Dell inspiron 1525 battery. So it auto turn off your backlight.
Jan 13, 2010 | Dell Inspiron 1525 Notebook
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell 1525 laptop keeps freezing
i am suspesioning on Rams. maybe overheating also does that.
May 30, 2009 | Dell Inspiron 1525 Laptop Jet Black
Xp Drivers for Dell Inspiron Laptop 1525
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
245 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
