Question about Kenwood KDC-325 CD Player
Does it have amp inputs/// (it it compatable with an amp?)
  • 560 Answers
You should have 2 RCA / Phono jacks on the back...These are the Hi Impedance outputs that send the signal to your AMP inputs, with the same type jacks...
Posted on Sep 02, 2010
Is there a way to install a aux input on a crosley cr-9 juke box radio? Thanks
You would have to break into the cassette player's audio output section. By finding where the audio joins the main amp of the unit. You couldn't do it via the record input section as that uses a different pre-amp which would not be compatible with CD. Once you find the point where the cassette audio joins the pre-amp section of the main amp, you should be able to take a link, from a pair of phono sockets that you will have to mount somewhere on the unit. If you don't use the cassette anymore than you can disconnect it. If you do want to use the cassette then the best bet is to also install a switch that will switch between the two. You will not be able to have both cassette and CD wires linked to the same pre-amp input. As one will vastly reduce the volume of the other. Which is why you would have to install a switch between the two.
May 02, 2017 | Crosley Audio Players & Recorders
Is an unidentified player compatible with an NAD integrated amp which has analog inputs?
As long as the "player" has phono connections you should have no problems with compatibility.
Jan 23, 2016 | NAD Audio Players & Recorders
Input not Support
It sounds like the resolution for your computer graphics are not compatible with your display.
In any case first thing to check is if the monitor cable has been disturbed; next try powering-down (everything) and leave it for a few minutes, power back-up and see if it fixes itself, if not Power-down, wait a few seconds, Power-up then press Shift & F8 as soon as Windows starts loading (you have to be quick, so might need several attempts), that should get you to the recovery Screen, then Try TroubleShoot and Automatic Repair.
Also, you might strt up in Safe mode. If your montor works, might be the driver.
Jul 26, 2015 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
My separates system do not seem to be compatible
By compatible I assume you mean you can't connect the separates?
The inputs on the amp. are usually phono sockets on the back. These are white and red (left and right - or the other way round, I can't remember) and may be marked "Phono/CD/TV/Aux" or some such. Your input devices will have corresponding cables to attach to these. Speaker outlets (for your speakers) will be marked clearly also. Like "SP1/SP2" or "Front SP/Rear SP" or some such. These are often clamps which grip the cables.
All the individual components will need power from a mains socket or multi-way socket.
If I'm way off I apologise.
Nov 14, 2014 | Audio Players & Recorders
Technics SL-L20
Hi, any turntable and amp are compatible. Modern amps however without dedicated phono inputs require the use of a preamp. Cheers john. Stylus City
Apr 29, 2014 | Technics Audio Players & Recorders
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
Need the manual to find out how to setup AV3 & AV4 as Component input, or if it is compatible with standard component input. Does not seem to work
Well, lets start here first. I would like you to look at the input jacks for a/v3 and a/v4 and see if they are color coded RED-GREEN-BLUE. or if they are just YELLOW-RED&WHITE (audio). If they are RGB then just buy RGB cables at your local Best Buy. If any are just Yellow and Red & White then those are just regular composite video the same as the old vcr's. You can't make A/V jacks work like RGB component jacks.
Dec 01, 2010 | Televison & Video
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Seeking compatable receiver for my Technics SL-QD35 turntable... what is the original? Will another be compatable?
I think I understand what you mean by matching receiver, but turntables and hi-fi in general is modular. This was sold as a single piece. You can hook it up to any receiver that has a phono input.
Or you can buy a separate phono stage and a separate power amp. See what I mean by modular?
I would goto a site like audiokarma and look through the amp forum. There are lots and lots of threads discussing the purchase of which amplifier.
Nov 29, 2008 | Audio Players & Recorders
Kenwood KDC-325 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
