My whirlpool cabrio he 4.5 cu ft washer keeps throwing the LD code what do I do?
  • 1,998 Answers
Error Code - Ld Problem - Long Drain Solution - When the machine consumes 5 minutes or more to drain out water to where the operating pressure switch resets
Posted on Sep 02, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Why does my washer wtw6200sw2 display an Ld code?
The Ld code is Long Drain. You might have a clogged hose. I had this problem once with mine. We had to empty the washer by hand and turn it on its front. Make sure you unplug it first! There is an elbow that I think was attached to the pump. We popped it off and it was clogged with dog fur (from washing dog bedding). Cleaned it out and put it back on and that took care of it. I found the diagram of the system online and suggest you look for it too - my memory isn't what it used to be - it'll tell you what to look for and where everything is. It could be the pump, too, but hopefully just a clogged hose.
Jun 07, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
May 23, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
The washer will not spin. All the lights are flashing and the indicator has an "LD" showing. The washer is 4.5 cu ft, 2006.
LD does mean long drain so the best thing to check is the drain pump itself and the connections to the drain pump. Remove all the water out manually (as much as possible) then tip the machine backwards so you can get underneath of it. Near the back is the drain pump and it's connected to the drain hose itself. Disconnect the drain hose as well as the hose coming from the tub and see if anything is jamming the drain pump motor or hoses. If everything checks clear and good, replace the drain pump motor, otherwise just clear out the blockage.
Feb 27, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
I have a whirlpool cabrio washer wtw6200sw2 and the eu code keeps coming up. We replaced the lid lock wiring and its still not working, Help!!!!
Welcome to fixya
I have a solution for this
Content
The error code your seeing more than likely is associated with the systems wash cycle. If your unable to wash at all, then the problem is located beyond the lid lock wiring.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Ld code
taking too long to drain,there is somthing in the drain pump intake or the drain hose is kinked. there could be somthing in the pressure switch hose makeing it think it still has water in it
Dec 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio dryer
af on your cabrio dryer means clean your air filter
Dec 14, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
