Question about Asko 1375 Dishwasher
Asko dishwasher doesn't seem to be getting any water.
  • Asko Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 02, 2010
I have an ASKO D5233, a little over 1 year old and the dishwasher does not clean well and often leaves stagnant water in the pump at the bottom and doesn't smell fresh after running. We clean the
Use white vinegar in your machine to kill mold. It's not your fault the dishwasher isn't cleaning well. They took phosphates out of dish soaps in some selected states. See if you're one of them.
http://water.epa.gov/type/rsl/monitoring/vms56.cfm
Jan 23, 2012 | Asko D5233XXLFI Dishwasher
Water doesn't seems to get into the dishwasher
HI,
Is it no water or little water? You could have a clogged inlet valve and this could be the cause. Check your water source coming into the unit, clean the screen and try again. Look for kinked water supply line as this can cause the same problem.
If this is not the case, get back to me with what you find out.
Thanks
Sep 09, 2011 | Asko 1385 Dishwasher
Unit has been flashing F1 and now doesn't seem to complete the cycle. Just keeps running.
The F1 error codes is a water heat fault,the control has determined that within 60 minutes that the correct water temp.has not been reached
The possible causes of that are
A burnt out heat element
A burnt out thermostat
Gene
Aug 22, 2011 | Asko 24 in. 1895 Built-in Dishwasher
Asko dishwasher 1875. Saying F2 fault. Reset doesnt fix. Water slowly running in constantly even when switched off. Pump runs if left on but if turned off it floods. any ideas?
Just wrote you a massive explanation then closed my window by accident. Lets try again!
From what you say, with water running even when powered off, this is certainly a mechanical failure of the water inlet valve. There will only be a couple of possible causes for this:
1) The valve is being jammed open by an obstruction, possibly grit in the water supply (did you have plumbing work done recently or work on the water supply in the street? This would be a classic cause). If an obstruction is the case then repeatedly starting a fill cycle, draining and satrting the fill again MAY shift the blockage.
2) There is a failure of the valve its self. Essentially it's just a valve with rubber seals operated by a small electro magnet and sometimes the seals fail (often as a result of a poor water supply allowing grit into the rubbers).
If the information at (1) above doesn't help, you may have to replace the valve (Though in examining it when you come to take it out, you may be able to locate and remove an obstruction).
To help you out there is a parts manual for your machine available in PDF here:
http://www.greatplainsapplianceparts.com/order/Parts%20Manuals/Asko/ASKO-Dishwasher/D3112%20(DW20.1)%20SS.pdf
Looks like the diagram on page 2 shows that you need part 135, although it seems to me that the author of the manual has got part 135 (Part No. 8073774 Cord Set) mixed up with part 140 ( Part No. 8073825 Inl. Valve Single 120V Sens.).
I imagine that if you go to the ASKO website and use the contact us option:
http://www.askousa.com/customer-care/contact-us/
They should be able to clear that up for you
Hope this all helps
Jul 28, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
Asko D1706 No water in the sprinklers
You can get access to the base from behind the dishwasher ,you will find about 6 screws to remove the back panel at the bottom to see if its leaking.
Feb 17, 2008 | Asko D1706 Built-in Dishwasher
Doesn't clean
check theres enough water getting into machine are you on tank water or low pressure water.
Feb 09, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1375 Dishwasher Logo
156 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
