Question about Lanzar VIBE1000.1D Car Audio Amplifier
I blew my amp up a while back and now that i have time, I took it apart. I know a lil about elec. and i know that i burnt up four of my capicitors and ive replaced them, 100v 220uf but ive also blown two small boxes on either side of my capicitor pack that read 224j100. I dont know what they are to buy them can u help?
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
Heater burns sooty
change your thermo couple if the pilot light will not stay lit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 26, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to find a short in my wiring harness for a 1989 honda prelude? The fuse blew and now my tach,gas gauge,clock and blinkers don't work I put a higher amp fuse in and it lasted about 5 days and blew...
at least you know were to start,key on the fuse that blew.and everything controlled by it.i'm assuming that every time you replace the fuse now,it blows .think back before the short,was there any electricial problems,or devices that didnt work.,wires are melted together,or motors are shorted out.putting a bigger fuse in probably burnt a wire open(meaning got too hot and broke)whatever blew the fuse to start with,is most likley where the meltdown is ,start unplugging the things on that fuse,one at a time,remove tail lightbulbs,inspect thre sockets,look up under the dash at the wiring ,your clock,tach.and gas gauge ,are there,observation is almost 90%of trouble shooting anything .fixing it is easy pop the hood spend some time just looking at every thing follow wires make sure they arent melted together ,and are plugged in,just unplugging something and plugging it back in will show problems,things will fall apart.clips will break and hopefully you will see something obvious,shorts are never fun,do you have any electrical background?and know how to use a multimeter .if you do reply ,
Sep 14, 2009 | 1989 Honda Prelude
Impala no sound ?
lol, the stock amp? if it blew its best to get an aftermarket one. better than the junky ones the dealer uses.
Apr 17, 2009 | 2005 Chevrolet Impala
Assembly of scroll wheel parts
Hi, We need more details such as what make & model your mouse is their are over 80+ different mouse's about so no one can help until full details are supplied by you. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 11, 2017 | PC Concepts EZ Scroll Wheel Mouse
Can I fix a fried amp?
Hi, how good are you with electronics? Are you able to open up the amp and see any obvious problems? I suggest that if your not very good with electronic circuits, get a professional to have a look at it, as if you damage it more by trying to fix it your self, it will probably cost you more to fix it. It may be as simple as an earth track been burnt, but even that in most cases will force you to completely disassemble the amp to find the problem. It may also be the diode right next to the power supply terminals that may be damaged and in some cases that can cause problems. Let me know if you open the amp, if possible post some pics and will see if there is something obvious that stands out. Cheers
Jun 06, 2006 | Alpine MRD-M1005 Car Audio Amplifier
Lanzar VIBE1000.1D Car Audio Amplifier Logo
24 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
