Question about E-Machines Computers & Internet
I cannot open messenger. I get an error message saying there might be a problem with your internet connection, but there doesn't seem to be a problem with that elsewhere
  • 808 Answers
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Posted on Sep 07, 2010
  • 70 Answers
Just reinstall messenger here: http://windowslive.com/desktop/messenger
Posted on Sep 02, 2010
Im using yahoo messenger version 11 .i cant sign in anymore .. other website like facebook n search are okay except in yahoo ..what are solution of this problem..pls help
i got the same problem with my ym 11 too.. but honestly looks like its ym problem that it may just work whenever it want to.. :( but try this.. open Yahoo Messenger click on "Messenger" (on top), choose "Connection Preferences" select "Connect via Proxy Server" try to log in ..
if it doesn't work put it back to the original settings, same instruction go to YM, click Messenger then Connection Preferences select "Connect directly to the Internet".. this time try to disconnect your internet connection first.. and then with your YM open enter your username & password but dont click "connect" yet.. connect to internet & log in to ym (you should click "connect on ym right after a second you are connected to the internet)
Sep 10, 2011 | Yahoo Messenger
Receiving error 81003004. HELP I can check messages... and have not changed my password, but can not open messenger... suggestions?
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, Example: if Broadband -> broadband(DSL/Cable).
Second Method
If any proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. Need to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Jul 31, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Thanks!
Jul 17, 2009 | Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
I m not able to open my yahoo messanger......
There are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Login error 81003004 from Yahoo Messenger
Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version.Hope it was helpful!
Jun 05, 2009 | Yahoo Messenger
Error code 80072745
http://www.tweston.co.uk/2008/07/26/windows-live-messenger-problems-80072745-solved/
This error is fixed by the solution here.
Nov 05, 2008 | Microsoft Windows Live Messanger
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
