Question about Dryers
Model#pye4557ayw--smelled a rubber odor and dryer quit. belt is on drum and okay
  • 66 Answers
Ck the belt pully under the drum .it may not truning .
Posted on May 10, 2008
Single old (disabled) lady having scares from the odor of burning rubber coming from my dryer. I barely survive on a fixed income and cannot replace my dryer. My best guess is that a belt is going o
its probably the drum rollers inside the unit that are dragging on the drum and making this burnt rubber odor, it would need to be dis-assembled and rollers replaced,along with a thorough interior cleaning and possibly a new drum belt, all parts about $50
Mar 11, 2012 | Maytag PYE3200 Dryer
My dryer flew off of a dolly when loading it on a trailer to move it. It smells like rubber is burning when I turn the dryer on. It was working fine until we moved the dryer. Could it be the belt is loose?
If the dryer fell some distance, the drum is probably out of alignment.
If the drum is not spinning at all, something has jammed the drum and the belt is being overheated by the motor pulley.
If the drum is spinning and there is a rubber smell, the drum has been knocked off of its rollers and/or glides.
In either case, the dryer needs to be opened. Click the link below:
There are two basic types of Maytag dryers, older models and the newer ones with the door that wraps over the top ('L' shaped door).
Apr 07, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Loud noices when running,some burned rubber smell
The only rubber part is the belt that drives the drum around. The belt rides on a tensioner which has a pulley on it with a bearing built into it. When the bearing goes bad the pulley will not turn freely causing the belt to get hot and smell. Its time for a new pully and bearing assembly for your dryer
Jan 31, 2010 | Dryers
I have a used GE DCLR333ETOAA model and last time was used it work for few mins. but smell like burn and then stop working. What you think it is?
If the machine quit and won't restart, I would be looking at the drum belt. Some machines will not start if the belt is broken. If the smell you are getting is more electrtical than a rubber smell you need to be checking the thermostats and make sure the venting from the back of the dryer to the outside is not full of lint because the safety thermostat will shut the dryer down so it doesn't overheat.
Jan 24, 2010 | GE Dryers
We have a whirlpool duet washing machine that is about 7 years old. During trhe spin cycle it makes a loud noise. Not the typical "airplane noise." There is also an odor. A burning engine odor. If you...
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help?
A few things could be going on here. If you are hearing metal on metal sound I would start with the blower wheel itself. Sounds like it either came loose from the motor shaft or it's broke. Other things could be a bad drum roller that has frozen up causing the rubber smell. Your idler pulley could be frozen up and the belt is slipping on the drum. Go to this link and post your model number to get a breakdown of your dryer. It wil show the areas I mentioned. back.
Feb 10, 2007 | Kenmore 63102 Electric Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
