Question about HP PhotoSmart C4385 All-in-One Printer
My printer is telling me that t can detect the cartridges, but they are in fact there.
  • HP Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
Why does my printer Brother DCP 165c cannot detect any ink?
Most problems with ink detection is the cartridge is dryed up. Even if you got it new it may have been on the shelf for awhile. Take a tissue and with the cartridge in your hand, make an impression on the tissue and observe the imprint. This will tell you if the cartridge is good or not
Aug 02, 2014 | Brother Office Equipment & Supplies
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
Ink refill not detected
you must reset the cartridges on mx300
check here the ways
http://inkfilling.net/instructions-on-how-to-refill-canon-pg-37-pg-40-pg-50.html
Jul 25, 2010 | Canon PIXMA MX300 All-in-One Printer
I have a lexmark X3650 printer. I have refilled my black in cartridge. (Drilled the hole and refilled). The printer does not detect the refill and keeps telling me the cartridge is empty. Help please!!!
Unfortunately, the cartridge has an indicator that tells the printer what its status is. This doesn't get reset when you refill the cartridge. With some printers, you can use a few other new cartridges and then try the refilled one again. (These printers store the cartridges last used and status; but can't store a long list of "this cartridge was empty".)
I wish I could be of more help.
Mar 04, 2010 | Office Equipment & Supplies
Printer is not detecting the cartridge
take a q-tip and rubbing alcohol and clean the contacts on the cartridge and on the printer. allow to dry and put it back in.
Dec 29, 2009 | Office Equipment & Supplies
Printer will not align
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | HP PSC 750 All-In-One InkJet Printer
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Will not print
I believe your problem is the fact the HP 1018 IS NOT a color printer. Black only.
Aug 08, 2008 | HP LaserJet 1018 Printer
Canon MP460 cartridge error
"Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator.
Lets hope for the best!
Regards,
Eagle"
Honestly.. There is absolutely no way for Those Canon printers to "look inside" or "Detect" the formulation of ink inside the cartridge...
Canon CL-31, CL-41, CL-51, CL-52 Print cartridges have the highest electronic _Failure_ rate of anything other inkjet cartridge on the market. Canon is aware of this. Replacing the Cartridge is the only sure-fire way of fixing this.
*sometimes the printer will tell you its the color cartridge, when in fact its the black cartridge. its advised to replace them both during these error messages.. it'll save you a trip, and the customer service rep's head. haha"
Using an Aftermarket or "re-filled" canon original cartridge is a sustainable resource for anyone looking to re-use an end-user item, and save money in this "tied-selling" market.
I proved you wrong by replacing my inkjets with Oringinal Canon PG-40 black, and CL-41 color cartridge. I ran them until they were empty. Bypassed the Ink Metering System explained to me through the canon software provided during the printer installation, and continued to print with them until they were 110% bone dry empty, laying absolutely no ink on the page. this took approx. 3 hours from perfect start, to finish.
If "canon printers have progressed so much as to distinguish formulations of ink" then.. this canon sure was the PICK of the litter. it continued to print *** as the day it was purchased, while not laying a single droplet of ink on the page.
get a life. stop dissing the aftermarket with your un-supported facts!
reguards,
inkjetech_007
Oct 10, 2007 | Office Equipment & Supplies
HP PhotoSmart C4385 All-in-One Printer Logo
283 people viewed this question
Seeker5211
Seeker5211
