Question about LG Studioworks 700S 17" CRT Monitor
THE POWER BUTTON FLASHING AND MONITOR DON'T WORK !
    Scholar:
  • 64 Answers
This could be an issue with either the monitor itself or the computer it is being connected to. The first step is to connect it to another computer if at all possible. This will determine if the screen itself is working. If it does not work with another computer, I would say it is time for a new monitor as it is almost guaranteed to cost more to fix than to replace.
If the monitor works with another computer the issue lies within you computer and is most likely an issue with the video card. The best bet would be to put another video card in place of the one currently in the unit, or one into the unit if a designated card does not exist. Plug the monitor back in and see if it works. If the problem still is not resolved or you are uncomfortable doing this, please visit a repair shop to avoid damaging any components.
best of luck //halfs
Posted on Sep 02, 2010
Emachine E109t6w flashing power button
means it has no signal and/or it is asleep. make sure all your connections are connected properly. if you have unplugged or plugged in the monitor lately make sure you don't have any bent pins on the vga cable.
Apr 12, 2012 | E-Machines eMachines Desktop PC
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Dell monitor flashing green power button black screen.
Your computer is in sleep mode, a low power mode that conserves power by turning off the screen and hard drive.
Push the power button on the system and the computer will resume.
If you don't like this feature, you can turn off sleep mode in the power options in Control Panel
Jul 26, 2011 | Dell Dimension 2400 PC Desktop
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
When I connect power to my Dell E198FP monitor, the power button flashes green and there is a small chirping noise and it won't display anything. It will also not allow me to power on/off the monitor but...
This is a failure of the power supply in the monitor. It can be easily fixed by replacing a pair of failed 680 microfarad 16 volt capacitors. If you have a friend who is handy with a soldering iron they will be readily apparent as failed since the top will "bulge". I just put this monitor back together and didn't write down the designators, unfortunately. This is the second monitor I have repaired with this failure...apparently the value is not terribly critical, just don't use caps with a lower voltage rating. I actually just replaced them with a pair of 100 microfarad 50 volt caps since it was what I happened to have on hand and the monitor worked fine once repairs were complete.
Nov 16, 2010 | Dell E198FP LCD Monitor
Monitor does not work power button flashing
Look at the pictures here for help.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Check those fuses, transistors, caps, soldering works, etc. Post back so we can guide you further.
Board:
http://www.lcdrepair.us
Apr 08, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
The power button is flashing on and off. get no image believe it is in saver mode, don`t know how to get it out. samsung monitor.
It is more likely to have problem in the power supply section, look inside for bad caps first then post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 29, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
LG Studioworks 700S 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
