Question about Sony Handycam DCR-PC1000 Mini DV Digital Camcorder
I am haveing issues with the display. when I take stills and video, half of the screen is clear and looks great.... the other half of the screen has a green hint to it. While you can still see everything and it is fairly good quality, the colors are not there and the green tint is starting to annoy me. I can not replace this camera because of what I use it for and the new HDD do not work for what I am doing.
  • 172 Answers
Its because only LCD cable.After replacing cable problem will solve
Posted on Sep 02, 2010
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Screen is now half hidden by what looks like a multicoloured barcode
If it doesn't clear after a reboot, you cancheck where the issue is by using an external display. If the external is OK then the laptop display is faulty. If it is also showing issues, you have a GPU fault.
Nov 23, 2013 | Samsung NP-N130-JA01US Netbook
I have a Vizio SV47oxvt1a flat screen LCD TV with a video problem. Half the screen (right) half displays different colors then the (left) half. Picture is clear both sides, just divided in half.
Most likely the screen driver has failed, thay atached to the screen and not replable! ps I don't fix flat screens under 46'' any more because of price.
Aug 06, 2013 | Vizio Televison & Video
Asus Ee pc screen is half white. how can i fix it?
Try to boot to the BIOS screen/ system setup screen. Tap on F2 on the splash Asus splash screen. If the BIOS still shows this problem, it is a hardware failure. You will either need to replace the LCD screen of the video card of your laptop. To further isolate the issue, you need to connect an external monitor on the portable system while you are on the BIOS screen and press on Fn+F8. If the issue is seen on the monitor, then it is the video card, if the external monitor is clear, then it is the LCD screen.
However, if the issue does not occur in the BIOS, it must be the video card. Hopefully it is just a corrupted video card driver. Try to uninstall and reinstall the video card driver. If it does not resolve your issue, then it is the video memory of your computer. You still need to spend some money to have it serviced.
Jul 02, 2011 | ASUS Eee PC 900HD Netbook
I recently updated this netbook using the Windows 7 upgrade and went through the entire tech support call with Microsoft regarding accurate procedures to upgrade from xp to Windows 7. The netbook worked...
To let you know one FACT....
MS tech support is JUNK....
If you still want to use them it's you call.....
Solution
Get an external monitor and fix that to the monitor port (watch this video)
http://www.youtube.com/watch?v=J7MZ23T-NRg&feature=fvw
on the back or on side of the notebook serial port
if display on monitor is ok then there is some issue with you laptop display
if hardware is the issue
you need to aproach a tech shop to fix the issue
OS upgrades dont spoil hardwares....
Nov 29, 2010 | ASUS Eee 1008HA Netbook
Is it my lcd screen or my video card
Please try to connect the laptop to a different monitor or display output like LCD or a projector, in case u find the clear images then the issue is with your LCD otherwise the issue is with your video card. The replacement of the LCD depends on the type of warranty you have.
Jun 20, 2009 | Acer Aspire 5004WLMi Notebook
I need to reset the Denon DN-D4500 to factory settings. How do I Do this?
Hi virg25
I took this instruction step from page 15-15 of the user manual.
On CD1 left side of the remote controller, to hold down track select knob down, "clear ok" will appear on the screen, press track select knob again, and select OK will clear all memos on the deck. memo clearing will display on the screen. Once clearing is complete MEMO CLEAR will display on the screen.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Jul 05, 2008 | Denon Audio Players & Recorders
Half of screen is not viewable
Well the issue is usally with the Video driver.Try reinstalling it from the support.dell.com and that should resolve the issue.Also you can try connectring a external moniter and see if you get the proper display on that or not.Incase you do than issue is with the screen and incase its the same on that as well than its an issue with the video card.You can get either of the two replaced accordingly.
Dec 27, 2007 | Dell INSPIRON 6000 CENTRINO...
My Toshiba laotp's screen goes half blank help!!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
Sep 17, 2007 | Toshiba (225EXTR5)
Sony Handycam DCR-PC1000 Mini DV Digital Camcorder Logo
159 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
