Question about Video Game Consoles & Games
Can i get STEP by STEP on how to fix an arcade machine?
  • 44 Answers
Http://www.youtube.com/watch?v=UiY2Ph_8u48.....or
  • the ATX power supply power up,
  • the VGA to the arcade monitor hookup,
  • the control interfacing and
  • the software set up. ...these are d four steps to repair an arcade machine...or www.arcaderepairtips.com/category/ sections/power-supply-wiring/
  • Posted on Sep 02, 2010
    How to fix an arcade screen on a big buck hunter safari machine?
    If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
    Apr 27, 2014 | Video Game Consoles & Games
    I BOUGHT A PAC MAN MACHINE THAT THE MONITOR STOPPED WORKING ON. EVERYTHING ON THE MACHINE WORKS EXCEPT i CAN'T SEE ANYTHING ON THE TUBE. I WOULD LIKE TO FIX MY MACHINE
    If this is a CRT type of arcade video game, it most likely uses an old-school flyback transformer, and a bunch of electrolytic capacitors. Check for cold or dry solder joints on all the boards (with the unit unplugged), and retouch any suspicious ones; especially the pins on the flyback, the CRT neck board/socket (if applicable) and in the power supply sections, where heat may be generated. Also check to see if the filaments light up in the CRT neck. It's also a good idea to check the caps in the power, horizontal and video sections as well - look for bulging or ruptured electrolytics, and/or burned resistors. Some arcade games (e.g. Asteroids) use a HV diode rated at around 25-30kV (it is located near the flyback and may have an insulated plug at each end). These can crack, short or simply go open circuit producing a "no display" symptom. If your game has this, check it before condemning the flyback or caps (the diode also doubles as a HV fuse). Do all the basic checks/visual inspections that you can thoroughly first before going any further with repair and/or restoration. It could be something really simple and easy to fix and/or obtain parts for (at reasonable cost if necessary).
    Dec 29, 2013 | Arcade Toys
    How can I fix my glitchy Tron arcade machine?
    it sounds like your vertical or horivontal sync is going out what i would do is take the old monitor out and i would buy a arcade rgb cga ega yup to vga hd video converter you can usually find them on ebay for 40 dollars or so then all you will need is a flat screen that will except a vga connection you tube can show you how to install these items into your game i have done several and you would be surprised how easy they are installed and if you get a used monitor you can save a lot of money also
    Jan 19, 2013 | Video Game Consoles & Games
    I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
    First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
    After doing this try to check your power supply and see if it is working well..
    see if the board look´s like this:
    Note that some versions has ide hdd interface.
    to help you, i find the service manual with all the instructions in this link
    There is a step by step guide to fix your Golden tee!
    Good Luck!
    Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
    I purchased an xbox 360 arcade 2nd hand, then purchased a bunch of old games that don't work on this model. i then puchased a 250gb harddrive but am still not sure how to update the console to be able to...
    Who exactly is "They"? By my understanding, the X-box 360 Arcade is NOT backwards compatible, meaning it cannot play original x-box games. The only one i know of that can is the X-Box 360 elite.
    Now then, if you go online to the X-box live Marketplace, they have quite a few original x-box games available for download, but you have to pay for them :( These downloaded versions WILL work with the 360 Arcade
    Aug 08, 2010 | Microsoft Xbox 360 Console
    I want to put my arcade machine on free mode
    there are buttons inside the coin door for programming. one button will bring you to programming mode on the screen and use the other(s) for selections. you can put it on free mode.
    Jun 17, 2009 | Namco Ms. Pacman Galaga Cocktail Video...
    Repair Service Arcade games
    i have fixed arcade games since 1990. let me know what you need: (happycarnivore@yahoo.com)
    Feb 25, 2009 | Arcade Golden Tee Unplugged Video Cabinet
    Video Game Consoles & Games Logo
    85 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
