I need to know the wiring connections for the power and reset on the asus p4sd-vl mobo
  • 32,281 Answers
On every motherboad I've come across the connectors are labeled on the motherboard.
If you still have problems, the go to the ASUS WEB site to download the motherboard manual. You may also need the motherboard drivers.
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Sep 02, 2010
Wireing
go to asus website type in mobo number download the manual, pictures off mobo fitting and all connections available
Dec 15, 2009 | ASUS P4V8X-MX Motherboard
Need to find a new alum&copper heatsink and fan combo
This is a standard micro atx board. The holes you are seeing will be on any 478 mobo, you just have to remove the black bracket, which is usually achieved by lifting the center pin in each of the corners.
Sep 02, 2009 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
P4sd socket 478 motherboard is not booting up at all !!!
1st check if the voltage from the plug has correct groung , neutral phase set .then
try a new smps , with minimum 400W output.
before connecting the same.
please remove all the parts out of the cabinet please connect only motherboard and smps and check its getting switched on , if not then your board is burnt you will have to replace it , if there is power indication then connect the RAM and check , if its also fine then connect the rest and try.
all this u have tried and no use , please post me a msg with full detail of your PC configuration , I can try a resolution
dil.
Aug 02, 2009 | HP Asus Motherboard P4SD-LA Socket 478...
Asus P4SD-VL Motherboard manual wanted purchase a new computer tower and trying to fit my motherboard and want a motherboard diagram or manual could some one please help! The connectors for the power...
I didn't find your exact model number, but if you want a detailed manual of your mobo the this is the link:
As I did not find your model number, please recheck the model number. If your numbers are correct you should be able to find the documentation you desire at the link above.
Aug 02, 2009 | ASUS Computers & Internet
apparently there is no manual for this, what exactly is your problem
Aug 01, 2009 | ASUS P4SDX Motherboard
I NEED AN INSTALLATION MANUAL FOR ASUS-P4SD-BO-R MOTHERBOARD
Select your motherboard by using the search in the upper left with key term P4SD
May 06, 2009 | Computers & Internet
Need manual or wiring diagram for this motherboard, thanks
Hello sir, I search for you and found a manual. Hope it is useful.You can see the wiring and everything. http://www.fixya.com/support/p362922-asus_p4sdx_motherboard/manual-11143
Asus P4GE-MX
If you have your manual you can see how to connect these on pg. 1-22. No manual..
Starting from the right edge of the board moving to your left. Notice there is two rows of pins one above the other. All your case connectors will be connected left to right & not up to down. The first two (BOTTOM ROW) pins are for the reset switch. The connector will have two wires one will be colored white or black. These colored wires are ground & will be the sane for all your connectors. All grounds will face towards the right for both rows of motherboard pins. After plugging in the reset connector SKIP one pin as you move to your left along the bottom row. Plug in your IDE LED connector a two wire connector. Moving to the top row across from the ide led, plug in the Power Led. It is a two wire connector. Some case connectors for the power led come in a three pin connector. If yours is like that than you will need to remove the + wire from the connector & slide it over one slot so it is next to the ground & plug it onto the board.
The last two pins is for the Power button. All Asus boards are marked & colored. You need a stronge flash light to see the markings on the board. Good luck!
Don't forget to vote..........
Jan 15, 2008 | ASUS P4GE-MX Motherboard
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
