Question about Maytag Ovens
Maytag electric range with ceran 4 burner top. Biggest burner will stop heating food after an extended period of cooking. Once range cools down, the burner works again. Suspect burner thermostat is faulty. Model MER5730ACW, several years old. This is the first problem we have had with it. What I have done so far: Opened top and checked wiring to offending burner and nearby thermostats and all looked fine. Checked voltage at the burner and got 240V with switch turned on.
  • robert_ma89 Sep 02, 2010
    This range has a glass top (ceran) and so does not have easily removable elements. Do you have experience with this model of Maytag range?
  • robert_ma89 Sep 03, 2010
    I will check the part number with Maytag service tomorrow for availability. Thank you.
    President:
  • 1,891 Answers
The biggest burner is i belive r front . the burner with limiter will have to be replaced as it does turn on and cycle but after warm up shuts down so burner element are of and tempt sensor is bad . just replace it and our good to go mm
Posted on Sep 02, 2010
  • dennis dodge Sep 03, 2010
    ck ing the cost and best way to correct element problem the element with limiter is 126.51 pt # 12500038 -- the limiter is n l a as a seperate part and can only be purchased with element . mm thanks for using fix ya . let me know if you need more help with problem **** ..
    robert the top is released by remobing the screw's under the front edge . then it will hinge up you do need a helper . I use a box to support top . the element is held by screws 1/4 in from the under side . have the new element there and unplug one wire at a time set the old element aside and install the new one in the reverse.. its not too tuff. and if you have a helper .. it will go easer. mm ( p s make sure to unplug range before lifting up the top . mm )
    Genius:
  • 1,478 Answers
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    GAS OVEN WILL NOT GET HOT
    see this instructions and fix it. God bless you
    1. eHow
    2. Home & Garden
    3. Home Appliances
    4. Other Home Appliances
    5. How to Troubleshoot a Gas Range Oven That Won't Heat
    By Kefa Olang, eHow Contributor
    Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
    Other People Are Reading
    Things You'll Need
    • Toothpick
    • Paperclip
    Instructions
      • 1
        Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
      • 2
        Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
      • 3
        Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
      • 4
        Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
      • 5
        Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
    Jul 18, 2013 | Ovens
    The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
    The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
    Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
    BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
    The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
    With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
    Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
    Stove top want heat up
    the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
    Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    All 4 burners do not heat up very well or not in red color
    I would CAREFULLY investigate that the electrical power is connected correctely. MAYBE you only have 120 instead of 240 on the one that doesn't heat well... OR maybe the element is defective.
    If you aren't adept at this you might get a service person to check it out as the voltages are lethal.
    The elements should get to a dull red color if correct.
    May 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Food spilled between the two pieces of glass on the door
    careful when cooking. u have to take the dor apart to clean this
    Feb 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Front right burner on GE glass top range not working
    If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
    Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
    The right front burner won't heat
    The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
    May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    128 people viewed this question
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
    Mack Baxter
    ashburton
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
