Question about Garden
My Craftsman model 358.795780 hedge trimmer starts ok but stalls out after a minute or so. Then it is dificult to start. Do I need to adjust the gas-air micture and if so, how do I make this adjustment?
3 Suggested Answers
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
I have a craftsman 358.796354 hedge trimmer that will start on full choke, throttle in the start position. But, as I move the choke from full it will rev up then stall. The only way I can get it to "r
It sounds like more of a carburetor issue but out of curiosity did they say why they thought it was a compression issue? Although craftsman is a little high on their parts a lot of the aftermarket parts such as a carburetor a lot of times are not all that expensive. I can't imagine you'd have all that many hours on it unless you use it commercially to warrant a compression issue. Might be worth a try.
Apr 14, 2013 | Craftsman 22" Gas Hedge Trimmer
Craftsman hedge trimmer won't start.
Have you changed the H T lead and then check the cut of swicth for faulty wireing
Jul 19, 2010 | Craftsman 22" Gas Hedge Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Will not start
did you try the air filter. could be not getting air. And are you sure it is firing. if so try a spray of ether. You can but at auto parts store. but be careful with it. don't use much. If it is firing it will go.
Jun 06, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman Hedge Trimmer model 358.796353 that won't operate
The problem you are experiencing is the coil. I had the same problem and confronted a freind that works on small engines. I asked him if the coil could be the problem and he gave me one to try out of another trimmer he had for parts. It is running well. The problem I now have is the blade tang that moves it back and forth broke. Now I'm trying to locate one of them.
Mar 28, 2009 | Craftsman 22" Gas Hedge Trimmer
Feb 16, 2009 | Craftsman Garden
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
