Question about HP PSC 1610 All-In-One InkJet Printer
Every time i go to print it shows and error - HP PSC 1610 All-In-One InkJet Printer
  • HP Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Show the error light
Hi Karthik,
Try this:-
  • Check the paper roll and probably re load it.
  • Turn the printer off.
  • Press and hold the power button and then switch the printer on.
  • Release after the first flash of LED light.
  • The printer prints a test page.
  • Turn it off and then on again and then try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Citizen CTS651 Thermal Printer
How to stop to print the journal after send fax everytime?
Sending Confirmation
This report shows the fax number, the number of pages, elapsed time of
the operation, the communication mode, and the communication results.
You can set up your machine to print the message confirmation report in
one of the following ways (see page 5.3):
• Automatically after each transmission (ON)
• Automatically only if an error occurs during transmission (ERR)
• No report printed at all (OFF). You can print this report manually at
any time you want.
SENDING CONFIRM - A confirmation report shows whether the
transmission was successful or not, how many pages were sent, etc.
Select ON to print a confirmation report automatically each time you
send a fax.
Select OFF to turn this feature off.
Select ERROR to print only when an error occurs and the transmission
was not successful.
Nov 27, 2010 | Samsung SF-5100 Plain Paper Laser Fax
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Print head error message
hi
if yr printer is under woranty u need to do company services system coz i think that u do what as u abov say that u do a initial stape or if yr printer not on woranty and if u know a normal clining system do cline pritner otherwise u need to replace head...
if yr printer show red light blink do press 5sec. then print it..may be it's help u if u have any quary tell me feel free...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Lexmark X6170 printer shows hardware error 0502 when printing
On the multi function machine there seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
You may have to do this from time to time if the error keep reoccurring.
Mar 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
My Inkjet 2800 won't print DWG. (CAD) files. I have no problem with other files; word, excel, photos ... When I try a CAD file, the printer shows "printer error."
Does the printer show you Printer error with number and letters following it? Prior to printing, check the 'print preview' to see how the layout of the printing is showing. If the CAD drawing is not adjusted to fit on the paper in the printer, you may from time to time get a printer error.
Feb 03, 2009 | Computers & Internet
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Error 5100
I Have the same problem. Greece.  This is the second services and I a lot overwrought with this instrument.
Him I was deprived 2 times and now one more time will again make installation of other instrument for the time of repair.
Rather I will reverse the sale in order to I finish with problems with canon.
actlaw@ath.forthnet.gr
Nov 17, 2007 | Canon SELPHY DS810 InkJet Photo Printer
HP PSC 1610 All-In-One InkJet Printer Logo
276 people viewed this question
Seeker5211
Seeker5211
