Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
What should the temperature setting be on for the kenmoreelite french door with freezer drawer on the bottom
    President:
  • 1,891 Answers
This one on me . the tempt for fresh food is 38 deg and freezer 05 + or - 5 deg . mm
Posted on Sep 02, 2010
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Water in the fruit and vegetable draweres
You might have the frig. temperature set too low. Set it at 38 deg. check actual temp. with gage. What happens is ice builds up in the drain tube that runs down to the bottom when the fridge defrosts therefore causing water to run into the veg. drawers. Ice buildup is preventing the water from running out at the bottom where it should. Just raise your fridge temperature a little and the problem should go away. Hope this helps.
Feb 04, 2013 | Samsung RF265AA Bottom Freezer French Door...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
Everything in the fridge and drawers began to freeze about 10 months after purchase. Reducing the temperature to as high as 46 F doesn't help.
Check the ice bank door to make sure it is closed properly. It is the door that covers the icemaker. Usually that is the problem that someone has left the door ajar leaking freezing temperature into the refrigerator.
Jun 17, 2011 | LG LFX25971ST Bottom Freezer French Door...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
161 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
