Question about Singer Sewing Machines
Just purchased a gently used Singer 185j sewing machine. Attempted to sew, but no stiches "take". It's threaded correctly and bobbin is also wound and placed correctly (has a drop in bobbin) also tried adjusting tensions (both upper and bobbin) but unable to produce a row of stiches. What could be wrong?
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
bargainbox
  • 1388 Answers
SOURCE: My sewing machine was not
Uneven tension on the bobbin is not good......check the instructions to make sure you have the correct flow of thread thru the tensioner....start again & try winding on at half speed, not flat out.
As to general tension issues, if you cannot find a small adjustment of the top tension works on a test sample, try this........
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on May 31, 2008
SOURCE: Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
Posted on Sep 07, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
I have a new Singer 5532
Put in a new needle. Unthread the machine then rethread it being sure it is threaded correctly--especially through the tension control. Remove the bobbin and make sure it is wound correctly. Replace the bobbin and being certain that it is in the correct position. Check the manual if you are unsure how your machine is threaded or how to replace the needle.
Oct 21, 2014 | Singer INGE 5532 32-titch Heavy Duty...
Why is thread is making multiple loops around bobbin
are you using pre-wound bobbins? or bobbins you've wound yourself? they might be too full or over wound (too much thread) this happens with pre-wound or some you've wound yourself. Also make sure you are loading the bobbin correctly. You also might try another bobbin, as sometimes they can get warped if they are the plastic kind.
Jun 27, 2014 | Singer 4423 Sewing Machine
Singer 328 is not stiching
if upper thread correct, check bobbin is wound and inserted correctly. Pulling bobbin thread, the bobbin should turn counter clockwise. make sure thread is under bobbin case tension spring. With cover plate open hold needle thread and turn hand wheel towards you to see if hook picks up needle thread and passes it around bobbin case. if not check hook timing
Jan 05, 2014 | Sewing Machines
Singer 2263 will not sew because bobbin thread winds back around the bobbin
have you tried changing the needle?
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin case & also wound correctly
May 14, 2012 | Singer 2263 Mechanical Sewing Machine
Singer5050 sews a little then jams top thread in pieces in bobbin area
Start from the begining.
Use your Instruction Book and make sure the machine is threaded correctly.
Adjust the top tension to about halfway.
Fit a fresh wound bobbin that does not have all sorts of different threads still wound on it(a bad habit with a lot of people).
Make sure the bottom tension is correct.
Make sure the bobbin is fitted corectly.
Set the machine to do basic straight stitch(mid range stitch length).
Try sewing and see if the problem is solved.
Apr 19, 2012 | Singer 8280 Mechanical Sewing Machine
Error 88 singer 7467S
I have singer 7467s and any time a sew it blinks 88 and beeps if the wheel is toward me. Otherwise it stays frozen.
Feb 07, 2012 | Singer 7467s Sewing Machine
When I use my Singer model 1120 for sewing straight lines, the thread bunches up underneath. What is the problem?
Be sure that the machine has been cleaned and oiled. Check to be sure the machine is threaded correctly. Check to make sure the bobbin was wound properly.
Oct 31, 2011 | Singer 1120 Mechanical Sewing Machine
Upper thread breaking on singer machine
Check that your bobbin thread is not wound too tightly or too loose. Also adjust your tension down a click at a time until it stops breaking, testing on scrap fabric. Singer provided manuals online. Look it up here: http://www.singerco.com/accessories/manuals.html
Sep 10, 2009 | Singer 3116 Simple
I have a Singer 9410 sewing mach. w/ tension & peddle problems
Be sure you are using a Class 66 bobbin for this Singer machine. Using another style bobbin can cause tension problems and thread looping/bunching.
Apr 23, 2009 | Singer 7442 Mechanical Sewing Machine
Stiches skip
Things to try:
1. New needle.
2. Make sure the needle is put in the correct way (there are fronts and backs to the needles).
3. Make perfectly sure that your bobbin is put into the bobbin case correctly (the thread going clock or counter-clock wise as indicated in the directions)
4. Make sure your bobbin thread is wound through the case and out as indicated by the directions
(these points vary DRASTICALLY by model of machine and brand).
5. Holding about 4 or 5 inches of top thread, rotate the flywheel (on the far right of your machine) by hand (don't use the footpedal). The needle should go down, it's thread creates a loop, and the bobbin thread loops through that loop; as you continue to rotate the flywheel, the needle will come back up, bringing its own thread AND the bobbin thread. This is when the machine is ready to sew (when both threads are up).
6. If your machine has been moved around and not very gently, then it is possible that the bobbin case and housing have been jostled out of alignment. If that's the case, then you'll need an experienced sewer to look at it for you - mostly that's a case of minor adjustment.
If you remember that the needle is flying up and down thousands of times in a minute, then having all these elements in perfect alignment makes sense.
Even experienced sewists get stumped with this, especially when working with a new machine.
Dec 30, 2007 | Singer CG754 Mechanical Sewing Machine
Sewing Machines Logo
267 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
