Question about Dishwashers
GE dishwasher leaks in middle - bottom - what part do I need
  • 1,998 Answers
You would need to replace the sump or rather the sump gasket but they dont usually sell the sump gasket without u buying a new sump and most of the time you pay more for just the sump then if you were to buy the sump and motor together as a kit you can find the parts at marcone appliance parts and they will mail you the parts directly before ordering the sump make sure you check the drain pump also it is located in the same area but when you usually have a leak it comes from the sump or the sump gasket but you'll have t crawl under and visually inspect where your leak is coming from please remember to rank this opinion on how it helped with your appliance situation and if i can answeer any further questions please message me back thanks again
rickead1
Posted on Sep 02, 2010
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaks
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
n
Jul 31, 2010 | GE 24 in. GSD4020Z Built-in Dishwasher
Water leaking from the inside middle of dishwasher. All fittings are tight
Leaking Dishwasher
heatman101
3yah
Mar 02, 2010 | GE Nautilus 24" Built-in Dishwasher
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Hello: I have a ge gsd5500 dishwasher. I want to remove the pump connect which is leaking. Key 455 This connects the pump to the main tub in the middle. How do you remove it? Thanks
Remove dishwasher from under the cabinet. Turn dishwasher on it's side. Loosen the clamp holding the motor/pump from the pump connect. Loosen the clamp holding the motor to the sump. Carefully remove the motor from the sump and pump connect. Turn the rubber connect counterclockwise several turns till it is disconnected from the bottom of the tub. Mine had a small crack right along the top. You needed to bend the connect to see it.
May 12, 2009 | GE 24 in. GSD5500G - Multiple Color...
Ldf8812st lg dishwasher leaking from front door
Thank you for the update. The retrofit kit will probably not only fix your leak but also dry your dishes much better.
I hope the info I provided was useful. Can you take a moment to rate my level of helpfulness?
Mar 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Water not draining in dishwasher leaking out bottom
Leaking Dishwasher
heatman101
ppp
Dec 11, 2008 | GE 24 in. GSD4320Z Built-in Dishwasher
Dishwashers Logo
159 people viewed this question
Top Dishwashers Experts
Owen Barnes
