Question about HP Photosmart 2610 All-In-One InkJet Printer
Hi have a hp2610 keeps giving error message remove and check cartrages.this done then reads remove and check cartrage on right.
  • HP Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
Inserted new ink cartrage, but printer saying remove tape from the ink cartrage. I've done that but it still say error. Also the not printing correct. I've had the ink cartrage for a while could that be...
Clean the contacts of both the cartridge and the print head with some alcohol. Reinsert the cartridge.
Power off the printer and wait 1 minute. Power if back on and then make it go thru calibration cycle if it
has one.
Mar 23, 2011 | Office Equipment & Supplies
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
After installing new ink cartrages the two red lights keep flashing and I can't check the cartrages to see if they are seated properly
Do you have a message on your screen ??? Try printing a document or opening the print manager and see the error message - that looks like a maintenance error when your pads need to be serviced after a set number of prints.
Press the button to set the carriage in ink change position - while your carriage is in the ink change position UNPLUG YOUR PRINTER.
ONce printer unplugged from electrical wall socket - remove all carts, and then place them back one by one making sure you use the right color for the right slot - make sure they snap in securely, close the latch.
Now plug in your printer and wait for the initialization process and see if this works....
If you still get the blinking lights, you will need to locate the error message - your printer pad counter has reached its maximum and it needs to be serviced and reset.
There are reset software out there, but you need to change the pads or divert the tube to a tank outside your printer.
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
K7100 black cartrage error (unrecognized)
push and hold the reset button for several minutes until it works again
May 27, 2009 | HP OfficeJet K7100 Photo inkJet Printer
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Hp color laserjet 2600n giving "10.0000 suply error"
10.00 error is for the black cartridge. Check the cartridge locker for the black toner cartridge on the right side, is it different from the other? does it moves correctly? check properly. If the locker seems correct, try clean the contacts on toner and opposite HV pins in printer
Nov 27, 2008 | HP Color LaserJet 2600n Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
642 people viewed this question
Seeker5211
Seeker5211
