Question about Garrity 2D Aluminum Flashlight
I have a Garrity Industries #06443....AND BELIEVE IT OR NOT.....I cannot figure out how to open the case to change the batteries. I can unscrew the top of the unit to access the bulb. And, I assume that the small, notched end of the unit unscrews to access the batteries. I just cannot open...even with channel locks. So, I want to be sure that is the correct way to access the batteries before i really crnak on it....Thanks for your help. Bill
  • Susana Nov 20, 2011
    How did you finally open it? I have the same flashlight with the same problem.
  • Joe Pankowski
    Joe Pankowski Aug 18, 2014
    After you unscrew the knoched end the battery compartment should fall out. No need to unscrew the little screws anywhere. Tap the flashlight if the old batteries are leaking and stuck.
  • 3,247 Answers
The notched end of the unit is the lid of the battery cover. It might be cross-threaded.
Immerse that end in hot water and then twist holding with a dry towel.
Hopefully that should open it.
Posted on Sep 02, 2010
How do I access the battery compartment on model 06443
To change the batteries in your flashlight, unscrew and remove the base tailcap, as the end that doesn't have the light. Remove the battery holder, replace batteries and then replace the battery holder in the same way that it was taken out (spring first).
http://ledmuseum.candlepower.us/fourth/gled.htm
Feb 21, 2015 | Garrity Camping, Backpacking & Hiking
Battery for spot liteS800G
Most likely has been charged as many times as possible. Time to replace the battery.
Jul 15, 2014 | Garrity Camping, Backpacking & Hiking
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
How do I put the battery into my new ibeam floating lantern?
This is an absurd situation. I am returning the flashlight for a refund.
Will never buy Garrity again.
Dec 24, 2009 | Garrity Camping, Backpacking & Hiking
How do you change the AA battery's for a Garrity Aluminum Flashlight?
If its the one I have ... A battery may have failed and leaked causing it and the battery unit to become stuck. I pulled off the top of mine and pulled out the LED assembly and banged it on the bench a few times and it popped out and I cleaned it up with some baking soda and water.
Sep 19, 2009 | Garrity Led Rch Flashlight
Can i change the battery on my ipod mini
You sure can!
ipodbattery.com
You may incur some minor physical damage to your ipod (like the case) but other than that it should be fine as long as your willing to open up your ipod! I replaced my ipod video with no problems, only a few dents in the plastic case, but since ipod mini is metal, you should have less damage to the case while prying it open, and i believe you open it by unscrewing some screws anyway...
Mar 07, 2009 | Apple iPod mini M9160LL/A MP3 Player
Garrity 2D Aluminum Flashlight Logo
1,520 people viewed this question
Top Garrity Camping, Backpacking & Hiking Experts
Tom Queen
Tom Queen
aron5566
aron5566
tjcwriter
tjcwriter
Are you a Garrity Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
