Question about Maytag SDE3606A Electric Dryer
When you start to dry clothes the dryer takes from one hour to hour fourty five minutes to dry.sometimes it might dry them in fourtyfive minutes. thank you.
  • 1,998 Answers
Most likely you have to dlint your dryer which means you have to take the whole thing apart and use a vacum to **** up all the lint lint is the main problem of a dryer and causes them to break down rather quickly if the lint is not removed you will have to take off the back panel and remove the lint filter tube off the unit here you should find alot this is were it usually gets trapped also go to the front of the machine and remove the front panel and use the vacum on the bottom of the unit throughtout the hole thing you can also remove the drum if you choose so that you can dlint it more thoroughly please remember to rank how this opinion has helped in your appliance situation and if i can answer any further questions message me back thanks again
rickead1
Posted on Sep 02, 2010
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
I have model #FGBD243KF1, Gallery 24" stainless. The wash cycle is taking almost 2 hours. Should it take this long? Also, when switching cycles during the wash time the motor whines a bit. Is this...
these units are pre programmed they can wash that longer and sometimes up to two hours and fourty five minutes. there are alot of factors involved.your unit sounds like it is running normally. at this time
Mar 27, 2011 | Frigidaire Dishwashers
Dryer takes 4-5 hours todry clothes dryer seems hot just not drying
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 08, 2009 | GE Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Clothes Not Drying well
1. Venting
2. Thermostat
Jul 31, 2009 | Whirlpool Dryers
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Maytag SDE3606A Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
