Question about Car Audio & Video
I put a stereo in and it says WAITING 03 - Car Audio & Video
    Genius:
  • 1,478 Answers
It is the error you get when you have entered the wrong radio code three times or when stereo have been disconnected from the car battery. You need a code to unlock your radio if it has been disconnected from the battery, check the document that came with it to see the unlock code to unlock your stereo.
Take care.
Posted on Sep 02, 2010
Rear speakers don't work. put new ones in
Are you using or trying to use stock speaker wires from the stock head unit stereo deck which ever one you want to call it
Mar 31, 2016 | GM Carts 02 03 04 05 06 07 08 Chevy...
Volvo 940 stereo EEE ??
It is showing EEE because of wrong codes being entered previously,.
To reset it, leave it SWITCHED ON...UNDISTURBED for as long as it takes.
This could be many hours as the waiting time doubles after each wrong code
Oct 02, 2009 | Car Audio & Video
03 Chevy Cavalier Replace Factory Stereo
I am currently in the process of putting in a new stereo in my 03 cavalier. It's actually quite a process but can be done with some patience. I really don't have the time for a highly detailed explanation but here is the outline. First pull the airbag fuse just in case, you'll see why. The dashboard will have to come out first. It all starts with the screw located inside the drivers side fuse box area. This will allow the dashboard to be gently pryed up and popped out, there are just clips holding. Keep an eye out for areas that are not coming up easily, there will probably be screws to take care of. (There are some in the glove box.) From here it's pretty self explanatory. The trim around the stereo must come out. Then the stereo. Not too difficult. You'll need a warning chime replacement harness. I used SCHOSHE #GMLAN2SR. You'll probably need a dash install kit depending on the size stereo you go with. You'll also need to wire the stereo to a switched source of power(12V ignition, orange). Have fun...
Jun 02, 2009 | 2003 Chevrolet Cavalier
Stereo notworking in ford focus
ahve you check you have put the blocks connecters onto the correct ones, or a cable may have came ouyt of the block.
May 22, 2009 | Sony Xplod CD Player w/MP3 Playback...
Replaced battery in my 03 ford focus now my car stereo will not power on. any procedure to reactivate my car stereo to turn. been reading horror stories about this setup. ugh!!
Not sure if this will help you , but many aftermarket have a reset switch behind the faceplate. would be a small hole about big enough to poke the tip of a ball point pen into.
Also , remove the faceplate and replace it making sure it is clicked in securly.
May 09, 2009 | 2003 Ford Focus
Want To Install New Stereo
You need to remove the front face on the dashboard...either you can "feel" your way through this, or you can get a basic manual like haynes that contains instructions. Most radios have accessory packages available that consist of an adapter harness and face plate which will make the job go a bit easier.R&R instructiona are not complicated but too long to write out.
Apr 23, 2009 | 2003 Jeep Wrangler
Fuse blowing on heater/air con control panel
put 1 size higher fuse in should solve he problem if not you will have to check to see if any wires are touching that sould not be for example on my stereo in my golf the live wire was worn so it was touching the chasis and blowing my stereo fuses
Nov 27, 2008 | 2005 Renault 181
Need car stereo code
Right what to do is if you dont no the code is put the stereo in the freezer for a bit soo the capisitors can cool down and de-elctroise and reset the settings :) i would rap it up in plastic bag make sure no water can get in and put it in for about 5minz.....
Jun 06, 2008 | Car Audio & Video
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
