Question about Watts Onan Portable Generator - 4000 , Model# 5500
Generator runs gets extremly hot then cuts off / three blinks / used in a rv
  • 44 Answers
Check coil and oil
Posted on Sep 09, 2010
How to fix onan 6.5 rv nhm gasoline generator starts but won't keep running unless you hold in start switch on
The power for the run side of start switch is not making it to the coil. Check wires and switch.
Jan 17, 2015 | Cars & Trucks
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
Sep 12, 2012 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
We have s6000 generator and a 38 foot camper that runs on 30amp. Do we need to buy and adaptor and can we use the 30 amp plug on the generator. And do we use the 4 prong or three prong
You will probably have to buy an adaptor. Read the owners manual for the generator, the 4 prong should only be for 240V. The 3 prong should be 120V. But READ the owners manual. If it is this way you should be able to get an adaptor at your local hardware/electrical supplier or any RV store.
Jan 31, 2011 | Electronics - Others
The RV i'm working on has 2 roof units,both start to cool then comp cuts off , there is 1 thermostat with dual zones,its on a 2006 motor home,it dorsn't seem like both would be bad
Can you get 1 to run good at a time, or does same happen when 1 only is run? Some RV's have an energy management system incorporated, that cuts power back to certain appliances when necessary. There were/are some units (RV's) that needed to be plugged in as well as generator running in order to run 2 AC units at same time. Let me know.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
We have an rv with a onan emerld I set generator on board. When we bought the rv (used) the generator did not work at all. We purchased the motherboard for it and it now starts and runs fine but we are not...
Is your generator wired in to an automatic switchover in the motorhome, or do you have external plug in on face of generator, or near it. The power from the generator needs to be attached one way or another to the motorhome. It may be as simple as plugging the cord from motorhome into it, depending on what set-up you have.
May 16, 2010 | 1983 Chevrolet Chevy
New Onan 4000 watt gas RV generator cuts out
The generator engine is jetted for sea level. When you run at 24 hundred feet, it's flooding out. That's what you smell. The carb will need to be jetted for high altitude.
Jun 30, 2009 | Electrical Supplies
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Generac rv altenator wiring
white is neutral black is hot and green is ground
Feb 14, 2009 | Honda 6370C - Parallel Power Kit For ...
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
286 people viewed this question
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
