Question about Brother HL-5240 Laser Printer
Erro Light status at menu Drum - Brother HL-5240 Laser Printer
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Drum light still flashing after replacing drum
Please remove the drum unit and clean the contacts of the drum unit and its chip on the printer. it should be located under neath the cover.
It just due to moisture and dust from old drum thats not reading the new unit. or try to go in the menu and rest drum supplies status.
Sep 23, 2010 | Brother HL 2140 Laser Printer
Yellow light on top front panel left hand side, what is this warnign for?
Couple options . pint a status report by holding down the main button until the printer starts making noise. Or browse the menus for Then look at the printed report for Toner, Drum, ect usage. Or if its a network printer Surf to the printers IP address and look at the status pages of the printer. last option. browse the menus with the button look for menu button >> information > something like status report cheers . ps sometimes yellow is "sleep" meaning power saver mode.
Aug 24, 2010 | OKI Office Equipment & Supplies
After printing several hundred sheets, status light went red. There was no paper jam. Let printer "cool down" overnight. Status light still red. Drum has never been replaced. Toner light is on. However, in...
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Jul 05, 2010 | Brother HL 5140 Laser Printer
What does drum end soon mean? Status monitor for my brother MFC-944)CN printer is saying Drum end soon! the file is being sent the status says ready, the paper goes through and comes out blank!
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
Jun 29, 2010 | Brother MFC-9440CN Laser Printer
Status light solid red not printing
Press the menu button for 20 sec and then try to turn on the printer
Sep 15, 2009 | Brother HL 5140 Laser Printer
Okipage 8w print drum
Reset the Drum Count:
Open the Status Monitor.
Click Printer Setup tab.
Click on Printer Menu button
Click the Maintenance tab
Click on the Drum Counter Reset button.
May 15, 2009 | OKIPAGE 6w Led Printer
Changed drum but it is still saying 'change drum'!
On some printers after you change the drum, you have to reset the counter so the printer knows the drum has been changed. How to reset the counter is as follows:
1. press the ONLINE button to return the printer to off line status.
2. press the MENU button repeatedly until the MAINTENANCE MENU is desplayed, then press the SELECT button.
3. Press the item button until DRUM COUNT RESET is displayed.
4. Press the SELECT button and the Drum Counter is reset.
Hope this helps.
Nov 10, 2008 | OKI B4350 Laser Printer
Photocopier 7013
You must reset in his menu! Go in setup menu or status menu and there must be reset Drum unit!!! But it's not the same cartridge and drum unit!!! It's separate part's!!! Give me exactly message!!
Jan 30, 2008 | Office Equipment & Supplies
Brother HL-5240 Laser Printer Logo
319 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
