Question about IBM ThinkPad R51 Notebook
I need lift the keyboard to put in more memory how do i do this.i put a gig in the underside of the laptop have the 512 i took out for the underside of the keyboard rf burke
  • 734 Answers
The link below will take you to the page where you can download the complete sercice manual (HMM) for your laptop with step by step instructions to replace your RAM
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-53169
Best Regards
Posted on Sep 02, 2010
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
I have 2 512 ram cards i tried to install a 1 gig card it didn't work and now my computer only sees one of my 512's
you need to pair memory modules. you need to buy another gig of memory and have it paired
Jul 09, 2009 | Acer Aspire 7110-2069 Notebook
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Adding more memory to my inspiron notebook
The second slot on the 2200 is under the keyboard.
Jul 31, 2008 | Dell Inspiron 2200 Notebook
Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
HI embreelynn,
just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
hope this helps, regards.
Jul 12, 2008 | Toshiba Computers & Internet
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Compaq x1000
The second memory slot is under the keyboard.
Remove two screws at the bottom.
Move downwards 4 switches at the top of the keyboard betwwen these letters (es-f1, f4-f5, f8-f9, f12-del) and raise it from the top.
Be careful not to remove keyboard ribbon-band.
There it is!!!!
Replace memory as standard.
Reverse procedure to set laptop to normal.
Nov 20, 2007 | Compaq Presario X1000 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
IBM ThinkPad R51 Notebook Logo
49 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
