Question about HP LaserJet 4650n Printer
Cuando instale a 5to usuario en red me salio un mensaje de error en la impresora 4650dtn laser el mensaje de error es el siguiente 49.4c02 reinicie o apague su impresora sale este mensaje y ya no quiere imprimir se planta. agradesco su colaboracion espero tener respuesta saludos.
  • HP Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
  • 1,218 Answers
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem.
http://www.fixya.com/support/t6031482-hp_laser
Posted on Sep 18, 2010
My canon imageclass mf4770n keep saying download waiting when i push the start button why
Voy a describir el procedimiento tal y como lo hice y logre revivir mi impresora.
1. Utilic? un equipo en el que jam?s fue instalada la impresora as? no instalar?a el driver autom?ticamente. (No s? si funcionar?a desinstalando el driver de la propia PC)
2. Conectar la impresora al equipo y esperar a que muestre el mensaje USB AVAILABLE. (IMPORTANTE. no instalen el driver de la impresora. Windows la reconocer? mas dar? error al no encontrar un driver compatible)
3. Descargar la utilidad de actualizaci?n de canon Win_MF4800_4700_FirmUpdateTool_V1504_usEN.exe
4. Ejecutar la actualizaci?n de Canon. Esta actualizaci?n deber? detectar el firmware da?ado y proceder? a actualizarlo. En mi caso fue el N?mero 4.
NOTA: es importante disponer de una fuente de respaldo (UPS) ante probabilidad de fallo en el suministro de electricidad ya que ante un fallo como este quedar?a la impresora inservible.
Sep 27, 2014 | Canon imageCLASS MF4770n Black/White Laser...
Hola, mi camara no dispara correctamente, al presionar el disparador se traba y aparece un rotulo en la pantalla que dice presione nuevamente y luego termina la foto, las fotos son de buena calidad... pero...
Cuando esto sucede en mi Nikon D-90, recibo un mensaje "ERR" en el panel de control. Nunca he conseguido un mensaje "vuelva a intentarlo". Sin embargo, suponiendo que esto es el mismo fallo, el manual del usuario dice que esto es un fallo de c?mara que puede ser aclarado por liberaci?n del obturador. En mi D-90 s?lo puedo hacerlo girando la c?mara y otra vez. A veces, tengo que quitar y volver a colocar la bater?a. El manual dice que si este problema persiste, debe enviarla a un centro de servicio autorizado de Nikon. Si lo que he sugerido que el problema no soluciona, sugiero que contactas Nikon support en www.Nikon.com para ver lo que proponen.
Dec 01, 2012 | Nikon D60 Digital Camera
A quien corresponda, tenemos el equipo HP Photosmart C5180 All-in-One, que presenta el siguiente problema: cuando se enciende, no termina nunca de iniciar el menu en el Display, se reinicia continuamente,...
Hola este problema, también lo estoy sufriendo... encontre la solución aquí, http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C5180-Power-Up-Power-Down-Problem-Loops-on-off-on-off/td-p/132152 son los foros oficiales del servicio HP, al parecer no se hacen responsables, es un fallo que ocurre a bastantes usuarios. Según comentan otros usuarios se ha de realizar la sustitución de unos condensadores, leer las 4 páginas del post. He dejado la impresora unas 3 horas aproximadamente en el bucle dichoso y finalmente ha arrancado. Igualmente en ese mismo post viene como hacer un reset a la memoria de la impresora.
Un saludo y espero haber servido de ayuda.
Mar 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
En mi imprsora lexmark me sale error 1203 cual es la solucion a mi problema gracias
El error 1203 son un asunto que ocurre o cuando un cartucho es malo o la Ranura de cartucho de impresora es mala...
1 - intenta de limpiar los contactos de cobre de la ambas ranura de carritos y carrito en la impresora y tratar otra vez.. O 2 - cuando error aparece,
cierre el poder de impresoras lejos; espere un minuto y g?relo atr?s en copia de prensa.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Feb 25, 2011 | Kodak ESP 5 Printer
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Nov 30, 2010 | Dell 3100cn Laser Printer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
HP LaserJet 4650n Printer Logo
202 people viewed this question
Seeker5211
Seeker5211
