Question about Akai LCT3201TD 32 in. LCD Television
When we turn our akai 32" tc-vcr combo on the screen is blue and it says main no signal. We press the source button and it does nothing. We can't get it to go to our cable so we can watch tv.
  • Akai Master
  • 17,130 Answers
The TV is working fine on the output and display drive but the problem is related to the microprocessor section. The source selection is a digital switch and it is not being active.
Please switch off and remove cable for about 6-12 hours so that all the charge in the system is drained off and if there was any errors to the micro procesor it would have reset.
If this wont work then the section related must be checked but your experience with electronics is needed.
Because the set is working fine otherewise any small errror can damage the set in this section.
But if you can check the +5 volt to the mP and the Oscillations of the crystal in the mP , then check for command to and from the mP as the remote is switched. You can trace from the IR detector to the mP . If mP is not reacting then it can be a suspect.
But to probe more you might need a CRO.( oscilloscope)
Check this out and comment.
Posted on Sep 02, 2010
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
DVD video showing without DVD in
have you tried pressing the dvd button twice on the remote?
Apr 13, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
May 16, 2012 | Akai Televison & Video
Blue Screen
Hello, If you are using this combo with cable and the channels just coming through, you will need to replace the tuner(mounts vertically on the main board and it's located directly behind the cable/antenna connector). If you are trying to use this TV with a set of rabbit ears, the free signal channels turnes digital last year and that is why you get nothing. The tuner as an assembly is still available from a couple of sources: Partstore.com and Union Electronics(johnl@ued.net)
Apr 23, 2010 | RCA T19064 19 in. Combo
Unit powers on, but SOURCE button cannot change screen from VGA
Hi
You have main board problem and coast for you with shipping $130.00.But we do only exchange.Please look at our policy:
ATTENTION:
WE CHANGE YOUR BAD MAIN BOARD TO GOOD ONE.
OUR POLICY
1.YOU HAVE TO SHIP AN OLD MAIN BOARD TO US
WE WILL SHIP NEW ONE TO YOU BY USPS IN 2-3 BUSINESS DAYS.
2. PLEASE PAY TO PAY PAL BUY FOLLOWING EMIL ADDRESS:
alenooshki@yahoo.com 3. PLEASE SHIP YOUR OLD MAIN BOARD TO FOLLOWING ADDRESS:
GEORGES ELECTRONIC
769 GLADYS AVE
LOS ANGELES CA, 90021
PHONE: 213 627 4071
FAX: 213 627 3944
THANKS
GEORGE
Feb 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Help! Pressed a button now only a blue screen!
Hmmm,sounds like you may have damaged the remote or maybe the batteries have run down where you where laying on it,try a fresh set of batteries in the remote or failing that try adjusting the tv manually by getting a chair,standing on it and pressing the buttons on the tv,also try another feed from another source just to make sure it is not the sattelite at fault.
Apr 20, 2008 | Akai CFTD2052 20 in. EDTV-Ready LCD...
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
Akai 20 in combo
These sets have very few parts available today and are considered throwaways. It will cost you more to repair I'm afraid then it would for a new set.
Oct 15, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai LCT3201TD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
