Question about GE Hardware & Accessories
GE 15071 timer died. Digits faded and disappeared, can't get to light any more. Both lights died within a weak of each other.
GBELECT
  • 23 Answers
SOURCE: I just hooked up my GE 15071 Smart Timer. When
What is the load on that circuit? It may be overloaded.Might be related to the switch having other items on the circuit. Try finding out what else is on this circuit. This switch is only rated at 15a general purpose,15a resistive, 15a tungsten Which is only 1,500 watts that would be 10-150 watt bulbs.
Posted on Oct 08, 2010
SOURCE: GE Indoor In-Wall Smart Digital
The timer is wired incorrectly.
ON the GE timer and Utilitec timer: The red and black wires are reversed.
On the Intermatic ST01C
Posted on Oct 13, 2010
jyackle5
  • 8197 Answers
SOURCE: I have GE in-wall digital
Welcome to fixya!
The timer should be wired like this.
All white wires put together.
The red wire goes to the black wire to the light fixture.
The black wire to the black supply/power to the wall box.
The green wire gets screwed to the box if it is metal.
Or you can look at the picture below.
If you would like the manual please ask and I will supply one to you.
Good Luck
Posted on Nov 15, 2010
SOURCE: I installed a GE 15071
If more than 1 timer is doing same thing, then suspect could be circuit or interference from Load.
Try timer on different circuit, on different circuit breaker.
Use cheap circuit analyzer from home center to test nearby outlet.
Otherwise, if you are buying timer from Home Depot, then maybe that specific batch of timers is bad.
I have tested 15071, and it is solid 7-day single-pole programmable timer without astro dawn-to-dusk feature.
Open following link to download on-line manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
You can also buy same-feature Utilitec 0141224 7-day Timer at Lowes.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Add a comment with your experience so others with similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 29, 2011
SOURCE: 15071 GE SMART TIMER BLINKING WHEN TURNED ON
Sounds like you connected white wire incorrectly, or are trying to replace 3-way switch.
GE 15071 and 15086 are for single-pole switch replacement only, and will not work for 3-way.
Open following page for correct wiring of GE in-wall timers, and for list of timers used for 3-way.
If you have different timer, add a comment with in-focus photo of your timer for correct identification and possible assistance.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Posted on Apr 22, 2011
Type of battery for GE timer 15071
The battery is build into circuit board and not replaceable.
The following 2 links have resources for 15071 programmable timer:
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
http://waterheatertimer.org/Programmable.html#15071
Nov 13, 2017 | GE Hardware & Accessories
I cannot program the "Off" time on my GE smart digital timer model 15071
Copy following link to identify timer:
GE 15071/ manufactured Tork SS720
Reset timer, and try again.
Push and hold reset button with paper clip or toothpick for 3-5 seconds.
Buy new timer at Home Depot and return defect with new receipt.
Otherwise instruction manual is straightforward, and would not accept ON time unless wired correctly.
Mar 19, 2013 | Hardware & Accessories
Intermatic/GE 15071 digital wall timer - Connection Problem
1) GE 15071 (Tork SS20) is single-pole timer, and cannot be wired as 3-way timer
http://waterheatertimer.org/How-to-wire-timers.html
2) Check wire nuts are tight
Remove light bulb and spray WD40 into socket. Reinstall light bulb
3) Reset timer using paper clip or tooth pick, then reprogram to see if functionality is restored
4) Move timer to different location and see if it controls different light
5) Buy another 15071 from home depot.
Remove bad timer, take photo of wires, and install new timer same wire-for-wire.
Return bad timer to home depot in new package.
This is GE's extended warranty plan, but do not mention warranty at return desk.
5) Intermatic and GE are fierce rivals in the timer business.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Intermatic makes their own products. GE timers are generally made by Tork. Both companies sell timers worldwide.
Feb 09, 2013 | Hardware & Accessories
Does timer 15071 automatically adjust for changing daylight length in addition to adjusting for daylight savings time?
GE 15071 sold at Home Depot and on-line has feature that adjusts for daylight savings time.
GE 15086 does not offer automatic adjustment for DST
Daylight savings time (DST) is not same as dawn-to-dusk astronomical timer.
GE 15071 and 15086 single-pole timers do not have dawn to dusk astronomical feature.
For single-pole dusk-dawn astronomical with DST, Lowes sells Utilitec-0192773
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
For 3-way switching, 7-day DST -or- dawn-dusk astronomical:
http://waterheatertimer.org/Aube-timers.html
Apr 17, 2011 | GE Hardware & Accessories
I have connected the Black wire to the outlet black wire and the red wire to the outlet white wire. The timer has a white wire, is this suppose to connect to the outlet ground wire? The timer turns...
I have extensive files on timers and don't recognize that GE number.
Possibly you have GE 15071 or 70 or similar timer.
Open following link to identify timer, and read step-by-step wiring.
Add a comment for more free help.
Mar 08, 2011 | Jasco GE 06685 24Hour Mechanical Timer...
May I hook up the GE Smart Digital Timer model 15071 in a three way system. I am replacing an Intermatic SS8C.
GE 15071 is single pole only.
Open following link to see GE 15071 timer, on-line manual, and steps for wiring:
Link also shows timers that work for 3-way switch and include links to those timers and manuals:
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 27, 2011 | Vacuums
I just installed a GE Smart Digital Timer. After I programmed the timer and went to manually turn on the light the light started to click on and off and the timer ticked?
Timer wiring instructions shown on following page:
You connected the white wire and red wire together, and that is why lights are clicking on-off.
I test timers and have done this intentionally during testing.
Follow instructions shown on link above, and GE timer will work correctly.
Same wiring applies to Tork, Swilight, Utilitec, Woods, Leviton, Intermatic non-battery operated timers.
Instructions are different for Aube, Brinks, UPM and Intermatic battery operated
Dec 28, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
