Question about Microsoft Xbox 360 Console
Ip addess when i test my xbox live connection my ip addess fails
  • ajv454545 May 10, 2008
    how to fix it
Fin IP address
Posted on Sep 21, 2008
If you are using an ethernet cable make sure its connected directly into your Modem and not a port in your PC
Posted on May 10, 2008
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
It wont go on live it keeps sayin fail when i try to connect
What does it say? For example ( IP Address failed?, DNS failed? Xbox Live Failed )
test your xbox live connection to do this
Mar 27, 2009 | Microsoft Xbox 360 Console
Cannot connect ot xbox live my ip address test fails
if you dont have a router, you can either have the xbox or the pc conneted to the internet, not both. you have to have an eithernet cord or a usb 2.0 high speed usb chord that goes directly from the xbox to the modem. you cannot go from the modem to the computer then to the xbox.
Jan 24, 2009 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
My xbox 360 says its connected to the internet, but it wont sign in on xbox live
To troubleshoot your Xbox Live connection from the Xbox Dashboard:
  1. Go to the System area of the Xbox Dashboard.
  2. Select Network Settings.
  3. Select Test Xbox Live Connection.
  4. After the system has completed its tests, select More Info to learn more about your network, paying close attention to any test that failed.
    In each case, the More Info section will offer tips for correcting the conditions preventing you from accessing Xbox Live.
  5. Select Edit Settings to adjust your:
    • IP Settings (including IP address, subnet mask, and gateway)
    • DNS Settings (including primary and secondary DNS servers)
    • PPPoE Settings (including user name, password, and service name)
    • Advanced Settings (including host name and altern
Oct 01, 2008 | Video Game Consoles & Games
IP address
Try this fix:
Apr 13, 2008 | Microsoft Xbox 360 Console
Xbox live connection?
When the Xbox live fails, it just means XBOX Live is currently down in your area. Give it a day then try again. If the problem continues, call microsoft.
Apr 11, 2008 | Microsoft Xbox 360 Console
Xbox live
ok, this is what i have to do whith normal computers.
(the xbox is the same)
(make sure youve got a crossover cable (red one))
1.turn on ur xbox
2.goto the system tab
3.goto Network settings
4.edit settings
5.ip settings
6.change it to manual
7.ip address
8.type in
9.Subnet mask
10. type in
11.default gateway
12.Type in
On your computer
2.control pannel
3.Network and Sharing Center
4.manage network connections (on side Bar)
5. right click on Local Area Connection
6. go propertys
7. doble click on tcp/ip v4
8. click use the following ip addess
9. ip address
11. subnet
13. default gateway
15. click ok
16. click ok
17. right click wireless network
18. goto propertys
19. got the sharing tab
20. tick the only box you can
21. press ok
22. your done!
phew that was a long one.
hope this helps.
Feb 09, 2008 | Microsoft Xbox 360 Console
XBox 360 not compatible with Motorola WR850G
Motorola WR850G router may fail to connect to xbox live after update to firmware 6.1.4. I was able to correct the problem. My solution was
Go in xbox >> network config >> IP and use Static option. Set the xbox to an IP in the range allowed by your router configuration. The router IP config range is found in the router config web >> Lan section. Then I set my router config >> Routing >> DMZ IP Address setting to the xbox ip I just assigned to my xbox. Restart router using the restart button on the Basic page of router config. Restart your xbox and attempt to login to xbox live. This solved my problem.
As a side note, on the xbox networking test page, the xbox live status message will allows show they are aware of a problem with xbox live login. This is a lie. For that reason I postponed trying to fix my router problem thinking it was an xbox issue, it is not. Once you finally connect to xbox live you will still notice this incorrect message remains. Microsoft developers ****...
Dec 26, 2007 | Arris WR850GP Router
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
