Question about Brother IntelliFAX 2800 Laser Fax
Machine gets hot
When I receive faxes or copy the paper gets so hot by the 3rd copy that it looks and smells burned.
Thanks for any help you can offer
I have to keep tapping the paper to get it to feed into the fax. I think the rollers are worn. Can they be replaced? is so how and where do I get the replacements?
Posted on Nov 07, 2008
    Scholar:
  • 159 Answers
Looks like the fuser is overheating. This means that you will have to remove the fuser and strip it down for cleaning and/or replacemnet of some parts, such as the thermostat, thermistor and hot roller.
Posted on May 12, 2008
Fax Spam
I couldn't find anything specific to delete the memory without actually printing it,
here's a copy of the manual if you need it:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FHD331%20Plain%20Paper%20Fax.pdf
May 26, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Smells hot and doesn't work
Unfortunatley, with laser printers it is not unusual to notice a burning smell. Sometimes that could mean that there is paper jammed inside your fuser assembly and it is being burned when power is applied. However, there could be a number of reasons why the machine won't function. My recommendation is to have a certified technician look at the machine for you. It may cost you $45-$75 to have someone check it out for and tell you what the cost would be to fix.
Jan 03, 2009 | Brother IntelliFax-4100e Fax
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
Feb 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
