My computer speakers are not working they are pluged up the volume is on not muted buy the computer says no device please help
    Sergeant:
  • 235 Answers
Some things to try.
1. check for viruses, spyware, malware, etc.
2. reinstall your drivers.
3. check your headphones jack and see if have sound there.
4. If all else fails replace your sound card or install one if the system has an integrated sound card on the mother board.
Good luck and let me know how it goes.
Posted on Sep 02, 2010
Everything is pluged in correctly. And when i go to the control panel> Sounds, speech, and audio devices> sounds and audio devices> volume, it says that their pluged in and work, but i dont here...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 16, 2011 | Dell A215 Computer Speakers
We have some speakers that we pluged up and it isnt working at all..im not sure why though..we have everything hooked up.. i checked theRealtek HD Audio Manager but i just cant get it.. Please help :)...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Jun 04, 2011 | Logitech S120 2 Speakers
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
I cant get any sound on my computer. it is telling meno audio output device installed. and is pluged in
Please just follow the steps to fix the problem
  1. Step 1 From the Task bar located at the bottom of your computer click once on the "Volume" icon.
  2. Step 2 Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
  3. Step 3 Right click on the "Volume" icon.
  4. Step 4 Select "Open Volume Control."
  5. Step 5 Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW synthesizer, CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
  6. Step 6 Right click on the "Volume Control" icon.
  7. Step 7 Select "Sounds and Audio Devices Properties."
  8. Step 8 Under the "Volume" tab, slide the "Device Volume" indicator to High.
  9. Step 9 Under the "Speaker Settings," click on "Speaker Volume."
  10. Step 10 Slide the "Left" and "Right" volume indicators to "High."
  11. Step 11 Click "OK." If this does not fix your sound issue, proceed to step 12.
  12. Step 12 Right click on the "Volume Control" icon.
  13. Step 13 Select "Sounds and Audio Devices Properties."
  14. Step 14 Go to the "Hardware" tab and select the "Driver" tab.
  15. Step 15 Make sure you are connected to the Internet and then, Click on "Update Driver."
  16. Step 16 After the driver has been updated, Click "OK."
  17. Step 17 Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 31, 2010 | E-Machines eMachines Desktop PC
HELP speakers aren't working
Hi
Thank you for your query
Please try the following
1) Ensure your speakers are correctly plugged into the back of the PC they should be plugged into a light green port
2) ensure the volume control on the speakers are turning and you have set them to a decent level
3) Click on Start>Control Panel>sounds and audio devices and ensure the volume is up and the volume is not muted
Please try the above
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Altec Lansing VS2121 Computer Speakers
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
We had to change the power box on our pc last one started to smoke due to fan dying, after getting everything back working we have no sound except the normal beep. the computer will not recognise a sound...
Speaker (right speaker) wire to GREEN socket. Open your device manager and see if any sound component is registering a splat...yellow ! Is the light on the speaker. Open sound and see that no X is in the mute box. Make sure the volume in turned up on the speaker and the computer. If all that is cool...reinstall the sound drivers for your computer. I don't mean to belittle you but its the little things that are missed can mess you up for hours-and man does it give one a red face. good luck , hope something here helps
please leave rating.
May 10, 2009 | Computers & Internet
Speaker problem
chk the right bottom of your screen for speaker symbol and check its not in mute and volume min position.
Apr 04, 2009 | Audio Players & Recorders
Creative 2.0 speaker not working
try checking the volume , the mute is on , drivers are loaded , if there pluged in, the nobs on the speakers
Feb 24, 2009 | Creative Labs SBS 270 Computer Speakers
No sound from speakers
Did you try reinstalling the sound card drivers?
May 10, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
