Question about Sony Ericsson W850i Cellular Phone
Cant open my phone,flashing red light on the power button when turning it on.
Ok i had pe and when i came back my phone was frozen it would't switch off so i took out the battery when i put it bak 2getha it wouldn't switch on it only showed a red flashing light. when i find a solution i will help you who have the same problem.
  • 1 more comment
  • laura1592 May 24, 2008
    i have the same problem my friend phoned me then when i tryed to end the call my phone froze so i turned it off and since then wont turn on and when i try to the on/off button just has a flashing red light
  • Anonymous May 25, 2008
    i had the same problem today.
    and now, i dont have anymore the flashing red light...
    my phone is dead??
    there are any solution??
  • jonpi542 Jun 10, 2008
    k 850i red light on power when i plug in charger wot do i do
Depends on what phone you have this may not work for them but if you have a sony ericcsson and it flashes red it usally menas that your rom inside you phone is dead and you need to replace the chip or buy a new phone
Posted on Jun 07, 2008
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Xbox not coming on what to do
hi, what do you mean by ti wont come on
is it totally dead or do you have any red lights lit up on the power button
check the power brick and when you switch it on at the main it should have an orange light on it then watch the orange light as you press the on button it should turn green to tell you it working or flash red if it has a fault let me know ok.
try unplugging all the leads out of the back of the xbox and switch the power lead off at the mains. then plug all the leads back into the xbox, no the power lead can be a bit funny at times so push it in then try forcing it in a bit further sometimes the connections get weak and you need to push it in further so try this pushing it in as hard as you can.
then switch it on at the mains then try pressing the on button if the on button still wont do anything try pressing the eject button as this will also switch it on and open the disk tray
if its totally dead or you have any red lights lighting up tell me how many then i can assist you further ok
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial as i have pages of unrated posts as users forget to leave a response, thanks
Dec 08, 2010 | Microsoft Xbox 360 Console
My xbox not coming on what to do pls help me
It wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Jan 05, 2010 | Sony Ericsson K850i Mobile Phone
Sony ericsson k610i stopped working press power button and red light flashes on top battery ok as tried it on another phone
Try leaving the battery out overnight. Then put back the battery in and try to turn on. If this didn't help, then your phone's software needs to be flashed.
May 09, 2008 | Cell Phones
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
W850i
you have no battery left... CHARGE IT!
Nov 24, 2007 | Sony Ericsson W850i Cellular Phone
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Phone frozen
i took mine to a verizon store...they wanted me to buy a new phone
Feb 24, 2007 | LG VERIZON VX5200 Hands-Free Headset...
Sony Ericsson W850i Cellular Phone Logo
154 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
