Service manual for mw511 Pride - Washing Machines
3 Suggested Answers
  • 713 Answers
SOURCE: need to replace the memory
Hi just read your posting.What country are you in?Is your control module faulty?Have you checked why the control module became faulty?Please reply for further assistance.Looking forward to your reply.
Posted on Sep 19, 2010
  • 6277 Answers
SOURCE: Fisher and Paykel Pride MW511 does not spin. Three
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
Mw511 pride top loader shows lid locked and issues loud beeping.Is mid cycle and full of water
When it beeps what is the error code? Look at the top row of lights and count from left to right.Tell us which of the 8 lights are on & which are off.
May 29, 2016 | Fisher and Paykel Washing Machines
MW511 PRIDE not filling with 2 water hoses applied correctly and water coming from taps but machine i getting no water....hot or cold
no power to activate the solenoids in the machine
check for power on
call a technician
is the door/lid closed [properly
May 24, 2016 | Washing Machines
Fisher and paykel mw511 pride wont turn on
Your pump could have blown the in the 4 amp in the board
Check your pump should be 34 Ohms
or higher, but not less then 28 Ohms if so replace pump and the fuse
The 4A fuse is near the AC plug on the board.
Apr 18, 2013 | Fisher and Paykel Washing Machines
GWL11 WILL NOT SPIN WILL NOT AGITATE. OTHERWISE WORKS FINE
not likely, I have attached a link for the service manual, download the MW511 service manual specified on the page
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Gwl11 will not agitate nor spin, everything wlse is fine
Service manual link below to diagnose fault
Download MW511 Service manual
Link:
I own a mw511 Pride fisher pakel washing machine. I have installed a new power board and the following lights come on; number 3 (green) nnumber 6 (orange), number 7 (orange), number 8 (red). are you able...
Hi - pls check the clear tube which controls the water level is fitted correctly - often there is a small nylon inside these, be sure its not inside the caught inside the controller as it may be blocking the passage way.
The problem is with the tube - kinked or not connected - check to see it maybe something simple.
Jul 13, 2011 | Fisher and Paykel Washing Machines
Where can i find an download a technical service manual for the Pride Mobility Legend XL SC3450 electric scooter? thanks..
I have downloaded a service manual for your scooter on this site.
You can e-mail me and I can send you a copy.
vhbcinc@gmail.com
Sep 24, 2010 | Health & Beauty
Need to replace the memory board on: f&p mw511 pride 5.5 washer, where can i purchase this from and how much
Sep 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
Need service manual and wiring diagram for Pride
'just search "mobile scooters", then go to the" pride "web site. You can download your manual, etcl or print it from there.
Aug 20, 2009 | Pride Jazzy Select 6 Indoor Power...
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
