Question about Brother IntelliFAX 2800 Laser Fax
Printer is Hot
And the copies seem to burn up. They come out hot and black after the 3 copy. Help Please!
  • Linda Dattilo
    Linda Dattilo May 10, 2008
    Thank you so much for the information!
    I hope this works. I've just tried everything I could think of. I'm not sure what the hot roller is. But, I can clean the fuser.
    Thanks again.
    Loanbiz 58
  • Linda Dattilo
    Linda Dattilo May 12, 2008
    Thanks Logjam.
    I will try this and see if I can make it work.
    I hate to through this machine away, as it has been execellent.
    Loanbiz 58
    Scholar:
  • 159 Answers
You seem to have a fuser problem. It may be that the thermostat is coated with baked on toner, so that it can't read the correct temperature. In that case it just requires that you strip the fuser and clean it all up. My guess is that you will need to replace the hot roller too.
Posted on May 10, 2008
Everytime I scan into computer or on paper, I get red/magenta all over the copied image. Also, replaced black cartridge, but anything printed in black is very light and faded. Help? Thanks
it could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested. or wipe and replace the ribbon
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
May 19, 2011 | Canon PIXMA MX310 All-In-One Printer
I can not get my copier to work at all it just leaves a j 3 message. When it was working black lines were being left over every copy page
where the black line being left when after the drum or before the fuser THe hot part. make a copy and stop the machine so the paper is in the middle catch it before it goes into the hot part are the lines there? be careful the toner will not be fuse your hand will smear the toner, if the lines are there you need to replace the cleaning blade and maybe the drum and get the image unit that houses the drum might need to be cleaned.
if no lines then the fuser is putting the lines on the copy replace the upper and lower fuser rollers and cleaning roller next to the lower fuser roller.
try this site as star to get parts.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 18, 2011 | Minolta EP1083 CS/PRO Copier
We are using a HP Laser Jet 4250 printer. The copies are extremely hot to the touch when they come out of the printer. Is this a sign that there is a problem with the printer?
if the copies are hot there is no problem because the toner and laser technology uses high temperature to bond the toner to the paper ( about 170 to 190 degres Celsius).
Dec 02, 2010 | HP Office Equipment & Supplies
My Samsung CLP-300 Laser jet is "burning" the ink when printing mostly dark colors which causes it to bubble and flake off the paper.
What kind of paper are you using? This printer does not work well with glossy paper and will do the things that you have described. Try using ordinary 20 lb copy paper and see if this makes a difference. If you are already using copy paper, then the problem is with the fuser, getting too hot.
Aug 02, 2010 | Samsung CLP 300 Laser Printer
Cannot get the magenta ink tank to flow in a Cannon Pixma 4500
Yes, you can take the printing head out  and soak it up in hot water. You can even blow some air on it, this will dislodge even the nastiest dried ink gunk. If even after that the head doesn't work then it's dead - buy a new printer.
Jul 11, 2010 | Canon Office Equipment & Supplies
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
Machine gets hot
Looks like the fuser is overheating. This means that you will have to remove the fuser and strip it down for cleaning and/or replacemnet of some parts, such as the thermostat, thermistor and hot roller.
May 10, 2008 | Brother IntelliFAX 2800 Laser Fax
Problem with Printing BLACK AND WHITE picture on Epson Stylus C88
i think theres problem on your printer head ..try to decloge printer using head cleanig on printer properties.. or other option is to removed printer head steam nozzle on hot hot water to easy removed clog make it sure its dry before you install and the last option is to replaced printer head... tnx good day.
Dec 14, 2007 | Epson Stylus C88 InkJet Photo Printer
Brother IntelliFAX 2800 Laser Fax Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
