Question about Proform 980 CS Treadmill
My ProForm J8li lights up, but the tread belt does not move. I have tried resetting it, I think. I hit the button at the very bottom and it turned the console off and then on. I need to know how to get the tread belt moving.
  • lmpeavy Sep 02, 2010
    I was told to get lubricant, even WD40 and spray the rollers well that roll the belt. I will try it tomorrow. I was told after sitting for 3 years, the rollers get stuck and dry.
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
  • 64 Answers
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Posted on Nov 18, 2009
6ylucy
  • 742 Answers
SOURCE: Where is the reset button on my Proform 750 CS?
Check your manual, if you don´t have one, ask here to find it:
manualfox.com/link/proform.htm
Posted on Jan 15, 2010
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
  • 13 Answers
SOURCE: NordicTrac C1800, Motor quits in less than 1 sec, console pwr ok.
motor controller shorted see me at mc70repairexpert.com
Posted on Feb 26, 2010
Proform j8li
810d2c26-b790-49c1-9641-93b05ea219e6.gifsee the video and lube .Of course you must do the same thign with rollers bearing front +back. Test the drive belt motor, and replace the belt if necessary.
However if after you lube the problem remain, is TIME to replace the deck belt by new ones.
You must test the control board, measure the input voltage for motor, if there are voltage the motor is faulty.
measure the output from control board if there are NOT voltage for input voltage motor, the control board is faulty , replace see the block diagram
God bless you
Aug 01, 2013 | Exercise & Fitness
Proform J8li
see the video how to fix the drive belt: God bless you
Jul 01, 2012 | Proform Exercise & Fitness
Hi, i have a proform 995 and the belt has shifted to the left side and is rubbing how do i center it?
hi you need to tighten the left side a turn or two and loosen the right side one or two. this is while the tread is on 3-4.once it moves over to where you want it. tighten the rite side . PS to tighten or loosen the bolts to the w/belt. clockwize is tight, and counter is loose
Mar 07, 2011 | Proform Power 995 Treadmill
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
Can't turn on proform sport 1000 no electrical response
try hitting the reset button on the bottom front area, its probly the breaker amp switch
Oct 24, 2010 | Proform Sport 1000 Folding Treadmill...
I have a proform j8li treadmill, all 4 led lights work properly. Console lights all seem to work. Incline works fine but no belt motor function
Jan 26, 2010 | Exercise & Fitness
Belt shifting/crooked and frayed on Proform 725 TL
in the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
May 09, 2009 | RTO Bodyguard T200 Treadmill
Looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
May 03, 2009 | Exercise & Fitness
Proform 980 CS Treadmill Logo
205 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
