Question about Sony Little Big Planet
Y does "failed to connect to players" come up over half the time i trie to join somebody!!!! and I getting mader by the second and ive been haveing this problem for a over a year now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Problem Solver:
  • 18 Answers
The game allows a player to not allow that person to come in: message that person with that PSN ID.
Posted on Sep 27, 2010
My bios is asking for a password on startup but ive never set one. Also ive herd of using a jumper to sort a soder on the back of the motherboard to reset bios,and ive seen it work but ive not seen it...
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
or
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
When inside the computer please be sure you're aware of the potential damage that can be caused by esd
Dec 30, 2010 | Toshiba Satellite A135-S4487 Notebook
P.O.S. sansa e200!!!!!!!!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 03, 2009 | SanDisk Sansa e200 MP3 Player
Music transfer
The songs could be in the wrong format - make sure they are in mp3 format or UNPROTECTED WMA format (90% of WMA's are protected).
If they are definitely in mp3 format (which I doubt):
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Feb 27, 2009 | Philips GoGear Flash MP3 Player
Ipod classic needs to be restore, how do i go about it?
Press and hold the Play and Menu buttons simultaneously for about 10 seconds. This will restart the iPod OS.
See http://support.apple.com/kb/HT1320 for more.
Jan 19, 2009 | Apple iPod classic MP3 Player
My creative zen doesnt charge
The problem maybe that the battery isnt any good.
did you always leave it on the charger for a long period of time?
if so then it could be no good. and i have had that exact same model so i know what size USB it takes so You can just trie getting one and trie different ones that way you can narrow down the problem. please write back
Jun 30, 2008 | Creative Labs ZEN V Plus MP3 Player
Wont Add songs
You may not have the right type of music there are different formats ACC, MP3 and MP4. So have a look and twiddle around with the settings.
May 13, 2008 | Philips GOGEAR SA6045 MP3 Player
PS3 online problems
ive got kind of the same problem....but my problem is....ive created an account and the internet is working fine on the ps3....but it says i need to upgrade the game (resistance & Motorstorm) to go online....and like half-way through the upgrade process it always says it failed to complete....any ideas??
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Continous restarting with white screen
i have no clue , have the same problem HEEEEEELPP
Apr 09, 2007 | SanDisk Sansa e250 MP3 Player
Sony Little Big Planet Logo
190 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
